DIYnot
Local | Network
   DIYnot > Forums
Local | Network
SOS!! Saunier Duval combi boiler - leaking water, no hot wat
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
uncy_chris
from United Kingdom
PostPosted: Sun Jan 28, 2007 11:16 pm Reply with quote
Hi, I hope someone can help. I have a Saunier Duval combination boiler. There was no hot water or central heating this morning so when I checked it showed the pressure was low (below 0.5 bar), and there was no flame showing.
I released the pressure valve and put the pressure up to about 3 bar and tried turning the boiler off and on to see if the flame would re-appear, but no luck. There is a strange leak coming from the base of the boiler that only occurs when the boiler is on.
Is there anything anyone can suggest? I've read, but can't find, the bleed valve which I gather would empty the pressure? I don't actually know where to find the model number, but if there's any experts here they might be able to determine it from the front panel, which is simply a timer, pressure gauge and temperature setter on the lower left, and an on/off switch on the right.
We had the boiler serviced about 2 weeks ago. If we need to get an engineer out, will a receipt for this service cover us for any extra work if we need to call an engineer out?
Cheers if you can help me.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 45 times
PostPosted: Sun Jan 28, 2007 11:18 pm Reply with quote
no wonder you ave a leak you are only meant to take the pressure up to 1 bar lmao
the PRV is opening when the boiler fires up and the water expands that wee bit get the service man back before you do yoursel an injury
before that try and get some of that pressure out of the boiler by bleedin a rad it takes a while mind
Back to top
 Alert Moderators
uncy_chris
from United Kingdom
PostPosted: Sun Jan 28, 2007 11:48 pm Reply with quote
Cheers,
Excuse my ignorance, but what's a PRV? How exactly do I "bleed a rad"? I've left it off for a while today and its lost some of the pressure. Shall I leave it to go down to 1bar and then see if I can get a flame? Or is this an engineer only job?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2527 times
PostPosted: Sun Jan 28, 2007 11:51 pm Reply with quote
A service is a very simple quick job which can be done by a pretty inexperienced person.
Your problem now is probably caused by you over pressurising the boiler.
Its likely to be an SD 620 or an SD 623.
This boiler is very prone to leaks and my general advice would be to replace it or get British Gas fault cover ( if they are stupid enough to cover it ! ).
Tony
Back to top
 Alert Moderators
uncy_chris
from United Kingdom
PostPosted: Mon Jan 29, 2007 12:20 am Reply with quote
Tony
Right, so is there nothing I can do? I'm only a tennent of the property and since we had to get an emergency engineer round to look at the boiler (and he ended up servicing it too) 2/3 weeks ago, I don't really want to tell my landlord its knackered again!
Would you recommend replacing it solely because its a notoriously bad boiler, or because the fault I've described sounds irrepairable?!
Cheers for the help so far gents
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2527 times
PostPosted: Mon Jan 29, 2007 12:33 am Reply with quote
Its an old and an unreliable boiler in respect of leaks.
We do not attempt repairs on that model when its leaking because to do so and offer any guaranty we would have to replace £150 of parts and spend 3 hours.
I dont consider its worth spending any significant sum on an old and unreliable boiler like yours.
Now you tell us that you are renting then this question is for the Landlord as he will have to pay.
I am sure some sharky boiler repairer will be happy to rip off your landlord and charge him £300-£400 to fix it for a few days.
Your landlord will probably prefer to spend this amount of money because he is mean rather than spending £1400 on a nice new condensing boiler. He can easily spend £300 a year on your old boiler.
Tony Glazier
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 44 times
PostPosted: Mon Jan 29, 2007 5:52 am Reply with quote
If it is an SD 623 there will be a lever for the summer/winter setting.
To the left there is a button which you have to press and hold to let the pilot gas through. Earlier versions I think had an ignitor button that you need to click a few times to light the pilot. Once the pilot is lit, hold the big button in for at least 20 seconds then slowly let go of it.
Its not your fault its gone wrong. Telling the landlord the bad news is a dirty job but someones gotta do it. Otherwise you will be cold until you pluck up the courage.
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 2 times
PostPosted: Tue Jan 30, 2007 3:34 pm Reply with quote
Very common for the reversing valve to leak not worth repairing
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 2527 times
PostPosted: Tue Jan 30, 2007 3:50 pm Reply with quote
I do not normally work on that model because its too problematic with its leaks!
Perhaps I have forgotten Slug, but I can only remember an electronic pilot ignition by pushing the white square button beside the red one which kills the pilot. There is a lovely arrangement of moving bits inside in a clear glass case at the back of those buttons. Pity the rest of the boiler is so aweful !
Tony
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 554 times
PostPosted: Tue Jan 30, 2007 4:00 pm Reply with quote
Replace pump (£150.00), reversing valve (£80.00), hose set (£25.00), arch kit (£15.00) +1/2 days labour.
Tenants deposit should cover it - after all they screwed it up. icon_lol.gif
Currently have a customer with BG cover on a Theilia 623 - taken them over 5 months to repair the leaks - they keep trying to condem the thing to make that huge profit on a replacement boiler.
Back to top
 Alert Moderators
eplanet
PostPosted: Sun Jan 09, 2011 7:32 pm Reply with quote
hi
can you help ?
i want to search for learning repair combi boiler. can you help me for find pdf or movies or any document ?
thaks
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Saunier Duval Themaclassic F35E combi leaking (fast!) 6 60 Tue May 08, 2012 11:54 am
Saunier Duval Thermaclassic F30E Plus leaking 2 760 Mon Feb 02, 2009 4:57 pm
Leaking Saunier Duval Thelia - but what's leaking?? 6 1160 Tue Feb 12, 2008 10:19 am
Saunier Duval Combi Boiler - What am I meant to do?? 14 100 Sat Apr 21, 2012 1:41 pm
Saunier Duval Combi Boiler won't repressurise HELP! 2 380 Thu Apr 01, 2010 9:29 am
DIYnot
