Trimming Venetian Blind slats?
5 Aug 2006
Manchester
Hi all.
I`ve just bought some venetian blinds for my bay window as it appears to be too difficult to get curtains in and for them to look well. So blinds it had to be.
The main window is 260cm wide while the side windows are around 45 -50 cm. So I`ve bought two 60cm blinds for the side windows and two of 135 or 140cm. Actually I've bought 2 sets (1 dark and 1 light) from ikea but there too short (155cm drop) and a set of dark from dunelm with a 160 cm drop.
So I'm going to use the set from dunelm, as they appear to be of better quality than the ikea ones, and due to the 160 cm fitting perfectly (155cm too short) they are cheaper than the ikea 250cm drop blinds.
So my problem is with cutting the blinds, B&Q have told me that they did have a machine but the company has pulled out of the UK!. I am reluctant to saw these individually so that leaves gathering them together, maybe in a G clamp or a workbench and sawing through them in bulk. Maybe I should use a hacksaw or a tenon saw.
Maybe I can get a blind fitting shop to cut them down for me, maybe you`ve done this yourself or know somebody who has. So do shops do this how much etc.
So I hope somebody will respond which will give me a better idea of what to do.
Vertical
When i did mine i closed them up and taped them very well together at the ends with masking tape and marked the line to be cut on the tape. then cut with an hacksaw. To adjust for the drop i put them up in my garage to work on. It was a lot easier to do this way then to do on the floor. Mine are from Dunelm and im happy with the look. Hope this helps
Hey Thanks ipjodan.
I'm just of to a blind shop to see what they say and I'll take it from there.
With yours how thick did it end up up with all the slats?
What type of saw did you use? Well blade in the hacksaw?
How smooth was the cut?
Did you need to sand them afterwards? (the edge that is)
Did the tape hold them firm whilst you cut them?
Did the tape mark the wood?
Sorry about all the questions!
Vertical
Not sure what you mean
Yes, get a brand new blade with more teeth the better
Very good
Yes, very lightly with wet/dry paper
Yes, use masking tape for this
No.
No. problem, hope you didn't mind me butting in although ipjodan may have done it slightly difference! ;)
Having said this, my blind was wooden, if it's a metal slats then best to get it done, also you have to look at the head to see if you can cut it back where you want it without hitting the pulley.
Thanks masona.
When I said how thick was it, I meant the dimensions of all the slats together, sort of a modular block of wood.
Anyway the blind shop wouldn`t cut down my blinds so I`m not paying there quote of around £320.
So I'm plucking the courage up or motivation to tape it up and use the hacksaw.
Oh, by the way how long did it take you to sand the edges of each blind?
Vertical
That would depend on how good you are with a hacksaw. ;) I've seen some people ragging at a cut with a hacksaw so the finished cut looks like a dog's chewed it. :rolleyes:
Any recommendations on which way to cut then, i.e through each slat or through every slat. If you know what I mean!
Vertical
Thanks but I don't have a bench saw. I think I would be worried about the ferocity of it if I did but I've never used one so I wouldn't know.
I think I'm sticking with the hacksaw and will have a go tomorrow. I've just being looking at screwfix for their range of saws. I was looking to see if a tenon saw would be better because of its stiffness and what type of blades to use in a hacksaw.
I was thinking that the more teeth the smoother the cut, earlier I bought a HSS 24tpi blade (2 in pack) rather than ordinary blades with 2 24tpi and 3 18 tpi blades. After looking on the screwfix website they seem to suggest that nearly all there hacksaws blades are more applicable to metal. There coping saws seems to be what they imply should be used for wood.
What do think about hacksaw blades?
Might be easier to use a mitre block, just take your time when cutting
images
I've thought about a mitre saw but mines a bit rickety, also I'd have to do the cuts in smaller sections which would be closely attached to each other so a bit fiddly. I do like the look of the blade on the mitre saw though and was thinking about using it as a hacksaw but I think the saw is a bit unstable.
So I'm still going to use the hacksaw, I think with the HSS 24tpi blade unless anyway on here causes me to change my mind!
Hopefully I'll get round to it tonight if I get the time although it might end up as the weekend!
Vertical
for mounting within the window recess? How much shorter than the recess would you trim them? Width wise.
Vertical
