DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Concrete corner-post problem
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
  View previous topic :: View next topic
Author Message
dougalthedog
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 05, 2007 4:27 pm    Post Subject:
Reply with quote Thanks
I have a closeboard fence at the bottom of the garden that was made using slotted and morticed concrete posts that take 3 arris rails.
I now want to replicate this fence up the left hand side of the garden and so join with the existing fence at 90 degrees.
The problem I have is that the existing fence was errected with an intermediate post at the point where the 2 fences will join. I have been told that a corner post should have been used but as it wasn't I would like to know is anyone has any better ideas than digging up and replacing the existing post.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WabbitPoo
from United Kingdom
Thanked: 3 times
PostPosted: Mon Feb 05, 2007 8:16 pm    Post Subject:
nope
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Mon Feb 05, 2007 8:58 pm    Post Subject:
cut the mortces yourself, easy to do. mark them out then cut most away ith a larger drill bit, then clean up with a sharp chisel. It should cut failry easily, if you can only go so deep then shorten the end on the arris rail to suit. i often have to do it as not all fences are that staright forward.
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
dougalthedog
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 11:30 am    Post Subject:
Thank you for your most helpful suggestion. I have an old cracked post that I will practice on first
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Feb 06, 2007 11:39 am    Post Subject:
Thermo wrote:
cut the mortices yourself, easy to do. .
?on a reinforced concrete post?
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Tue Feb 06, 2007 2:24 pm    Post Subject:
Doh, sorry dont try this at home. try reading the bloody post properly first....missed the concrete bit! icon_rolleyes.gif Still if you do manage to do it can you post some pictures! icon_lol.gif
__________________
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Tue Feb 06, 2007 3:23 pm    Post Subject:
If I'm reading right, can you not put in a timber on the opposite side of the slot and with screws from the fence panel side, most of the concrete have screw holes then the arris rail fix to the timber at the back or is the answer still nope icon_lol.gif
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
dougalthedog
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 9:45 pm    Post Subject:
I had thought about drilling 2 or 3 holes into the existing concrete post and rawlbolting on a timber cut with a slot and mortices.
Has anyone got an opinion on this plan – bearing in mind I only have a bog-standard 240v hammer drill
Back to top
 Alert Moderators
ModernMaterials
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 06, 2007 11:50 pm    Post Subject:
Could you screw thick noggins of timber on to the concrete corner post and then screw the arris rails on to the noggins?
Or even better, could you find some chunky L shaped aluminium and use that instead of noggins?
Back to top
 Alert Moderators
nnikjo
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 29, 2008 7:02 pm    Post Subject:
make it easy on yourself and just dig up the old post and replace with the correct type of post it will save you trouble in the long run.rawl plug and drilling is liable to split the post
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Apr 29, 2008 7:36 pm    Post Subject:
nnikjo, may i suggest you read the date before you post, he has probably done it now since has asked back in 2007
forum rule 8
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Replacing Corner Fence Post (8ft) 4"x4" 27 880 Fri Sep 04, 2009 1:48 pm
Hozelock corner bracket fixing 3 360 Sat Jun 21, 2008 1:33 pm
laying patio -Do i lay corner to corner for random paving? 4 1680 Wed Apr 09, 2008 12:15 pm
concrete fence post problem 4 4220 Thu May 18, 2006 3:38 pm
Closeboard problem -loose arris rail in morticed wooden post 8 220 Sun Sep 13, 2009 7:54 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
