Hi, I hope one of you will be able to help me. I live in one of those houses where you start doing one thing and 100 more problems appear. Yesterday decided to replace a socket which had a worrying discolouration (looked like burning) around the pin holes. It's on a ring main, looks like a spur coming off it as 3 wires going into the back. BUT, when I wired it all back up again the circuit breaker on the CU will not switch back to on. Presuming I have an earth problem so tried to isolate the problematic wire from the back of the socket but even with all wires disconnected I cannot get the supply back on again. I know that the best advice and what most of you will tell me is to get a professional in to look at this but I just don't have the money (I know this sounds mean but am trying to look after elderly parents in their own home and there is nothing spare). I can completely isolate one side of our house (two different CU's) which I have done. Any advice on how to get the juice running again would be so appreciated.
I normally try to avoid the more complicated electrical/plumbing jobs, unfortunately what should have been a little job has turned into a larger one and I can't afford a professional.
Thanks.
Thanks.
