DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Creda Electric Shower = Low Pressure
Author Message
cardiffdutch
from United Kingdom
PostPosted: Mon Feb 12, 2007 1:08 pm Reply with quote
I replaced an old essential shower in my house for a Creda 550c 9.5kw shower. After I installed I wasn't happy with the force of the shower so I changed it for the 10.4kw version and it improved slightly but not much. Both of these new units are way less powerful than these new units. I don't get a low pressure warning either. When the flow is cold it is very powerful but as soon as you increase the temp it is pathetic.
Any ideas??
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 446 times
PostPosted: Mon Feb 12, 2007 4:07 pm Reply with quote
First of all, what is supplying the shower?
What size cable, switch, mcb, rcd, CU, and is there any bonding?
Back to top
 Alert Moderators
cardiffdutch
from United Kingdom
PostPosted: Mon Feb 12, 2007 4:24 pm Reply with quote
The cable is 10mm shower cable. I had to cut the old cable and connect another piece to it as the old cable wasn't long enough. I connected the cable by using a junction box (i think thats what its called). Im not sure what the other things are you are asking.
Thanks for the response.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 12, 2007 4:48 pm Reply with quote
I hope it was a 60A junction box...
Back to top
 Alert Moderators
cardiffdutch
from United Kingdom
PostPosted: Mon Feb 12, 2007 4:55 pm Reply with quote
I think it was - Exceuse my ignorance but would that affect the showers performance. I presume there is a risk of blowing the shower and tripping the house if it isnt a 60amp junction box.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 864 times
PostPosted: Mon Feb 12, 2007 4:58 pm Reply with quote
Overheated junction boxes toast themselfs and turn into carbon which conducts electricity where it should not be going..
Back to top
 Alert Moderators
cardiffdutch
from United Kingdom
PostPosted: Mon Feb 12, 2007 5:03 pm Reply with quote
I will double check tonight - Have you got any ideas of what could be causing the poor performance. I am thinking of chnging it for a Mira shower as I have heard that give the best performance.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 446 times
PostPosted: Mon Feb 12, 2007 8:18 pm Reply with quote
If your JB is round, you have installed an entirely inadequate one. AFAICT, you can't get round 60A JB's.
There should be no unneccesary joints in a cable like this.
What about the rest of the circuit?
Switch size, MCB size, RCD present, which CU have you got, bonding etc, etc..
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Mon Feb 12, 2007 8:25 pm Reply with quote
To add, you NEED to know ALL of these particulars BEFORE you make any change to a shower circuit. Without knowing these, you could be making a totally dangerous situation by fitting a higher powered shower or making other modifications.
Also note that modifications to fixed wiring in a bathroom is notifiable to your local building control under part p of the building regulations. You are breaking the law by doing this work and not notifying.
Please get an electrician in to ascertain the safety of your shower circuit.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 377 times
PostPosted: Mon Feb 12, 2007 8:55 pm Reply with quote
I agree - and do not use it again until you have!!
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Electric Shower - possible pressure issue 10 1680 Tue Jan 23, 2007 12:30 pm
electric shower low pressure 13 440 Sat Nov 20, 2010 4:14 pm
Mira vie 10.8 shower pressure problem 19 1760 Mon Dec 21, 2009 5:19 pm
Low pressure/temerature problem on Triton Opal shower 3 400 Sun Oct 10, 2010 6:14 pm
mira sport shower 8.5kw, low pressure light 13 180 Sun Sep 04, 2011 2:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
