| Author |
Message |
JACKC
Joined: 14 Nov 2005 Posts: 345 Location: United Kingdom Thanked: 10 times
Posted: Mon Feb 12, 2007 8:19 pm |
Does anyone know of anything I could look at for this fault.
when driving and dip clutch to change gear when approaching a junction the engine does not idle but cuts out, the first light to light is the glo plug lamp. Usually worse when cold but not only when cold. Happens if you dip clutch to see if faulty when coming up to a junction. This gives me time to jump start as normally very hard to start when cut out. Havn't a clue what to do. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
libby lou lou
Joined: 16 Oct 2006 Posts: 3584 Location: Lancashire, United Kingdom Thanked: 43 times
Posted: Mon Feb 12, 2007 9:33 pm |
When was the fuel filter last changed, just a thought. did YOU do it yourself? (starting at the bottom) what year? |
| Back to top |
JACKC
Posted: Tue Feb 13, 2007 8:53 pm |
Its a 52 plate with 160k on clock, came from a local firm who had it serviced by good friend of mine, full service history from him since new. He is checking his records but assures me all filters replaced as recommended. Is it worth just changing this to rule out? |
| Back to top |
JACKC
Posted: Tue Feb 13, 2007 8:54 pm |
| Back to top |
libby lou lou
Posted: Tue Feb 13, 2007 9:32 pm |
sorry to stop you there JC, but what you really need to do is go and see your good friend, if he has serviced it all it's life, nobody knows the vehicle better, maybe the driver, i imagine he would have a good idea of the way things are on the van. ie, has this happened on other vehicles? |
| Back to top |
JACKC
Posted: Wed Feb 14, 2007 11:27 am |
already booked in, thanks for all the replies, apparently its not happened to this van before and he hasn't heard of any common probs like this |
| Back to top |
tekkiesteve
Joined: 11 Feb 2006 Posts: 77 Location: United Kingdom
Posted: Mon Feb 26, 2007 12:14 am |
Sounds like mass air flow sensor. |
| Back to top |
JACKC
Posted: Tue Feb 27, 2007 7:24 pm |
thanks for that, will pass on to my mechanic. |
| Back to top |
robcalvert
Joined: 11 May 2007 Posts: 5 Location: Leeds, United Kingdom
Posted: Fri May 11, 2007 11:01 am |
I had same problem with mine. Eventually discovered it was flywheel/speed sensor that was contaminated with oil, took out and cleaned with carb cleaner, drives fine now. It's located at the front right at the bottom of engine/gearbox with 10mm bolt. |
| Back to top |
JACKC
Posted: Fri May 11, 2007 11:06 am |
Thanks, will give that a go. hasn,t done it for ages and then yesterday reared its ugly head again. Mass air flow sensor still not replaced as fault went away. Will try your suggestion first as seems easier than a replacement part. Thanks again for taking trouble to reply to such an old post. Will let you know. |
| Back to top |
robcalvert
Posted: Sun May 13, 2007 8:25 pm |
spoke too soon - did it again yesterday but this time the connectors inside the black plastic plug that pushes onto sensor were loose-has had new gearbox in before I bought van so could have been disturbed then. Might be worth checking them when you take sensor out. This may have been the fault in the first place. I'm hoping it's cured now - can be very frustrating - will see what happens. |
| Back to top |
Francisd
Joined: 14 May 2007 Posts: 2 Location: Cumbria, United Kingdom
Posted: Mon May 14, 2007 2:04 pm |
I’ve had something similar but was not as bad. On cutting back the throttle after a long full-throttle uphill drag, the gloplug alarm light came on and the power was severely limited. A 10 minute stop to let everything cool a bit let everything re-set and it went away fine. It’s done it a couple of times since, but easing the throttle back gently, rather than a sudden cut back, seems to stop it happening again. I asked the dealer at the next service and the mechanic reckoned the Low Pressure Fuel Pump at the tank was on its way out, he also found metal fragments when he changed the fuel filter. I’m fitting some seats to the back so I need to drop the tank anyway so I’ll probably change the LP pump while the tank’s down. Does anyone have any drawings or information on how to drop the tank? I used to rely pretty heavily on the likes of Hayne’s manuals with my other vehicles but I’ve not seen anything similar for a Vivaro, If anyone knows where I can get hold of the Technical Literature for the Vivaro it would help me out a lot. |
| Back to top |
JACKC
Posted: Mon May 14, 2007 2:33 pm |
My mechanic went down the road of LP pump when he had a look, but didn,t fee convinced enough with his diagnosis to risk the work. Funny you mentioned the glow plug as this is the first indication of what is about to happen, as soon as clutch dipped, light n and you have a second to re-engage and keep revs up. Havn't tried fywheel sensor yet as been on nights. |
| Back to top |
Francisd
Posted: Mon May 14, 2007 2:49 pm |
That’s a poser. Do I change the pump or not while I’ve got the tank down? |
| Back to top |
robcalvert
Posted: Wed May 16, 2007 5:54 pm |
Doesn't seem to have worked unfortunately , started playing up again. Damn thing's doing my head in now. Vauxhall didnt seem to know either , even diagnostic machine not forced to pick up the fault unless it does it when testing they said. Might change van if can't find problem soon but not giving up just yet ! |
| Back to top |
