Sean2806
Joined: 20 Feb 2007 Posts: 1 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Tue Feb 20, 2007 1:40 pm Post Subject: Dimmed lights and extractor |
is it possible to wire a timed extractor with the perm L and N coming from a independent supplied fused 3A spur, then connect the switched L from the lighting curcuit to the fan, tried it but it seemed to bypass timer function and make the fan run all the time, does the perm L and N have to come from same circuit as the switched Live? PLEASE HELP ME
P.S The bathroom lighting that i ran the switch cable from are controlled by a dimmer switch, |
ricicle
Joined: 14 Sep 2006 Posts: 3485 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Tue Feb 20, 2007 5:30 pm Post Subject: |
Why would you want the L/N from a different supply to the SL?This is dangerous if the FCU is on a totally different circuit to the lights!
The SL would not work if it is via a dimmer and the dimmer is turned down
I hope your dimmer is not in the bathroom!! __________________ Empty barrels make the most noise. |
securespark
Joined: 11 Jan 2004 Posts: 16480 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Tue Feb 20, 2007 9:18 pm Post Subject: |
Unless in Z3 at a pinch... __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
