DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Ceramic Tiles on Upstairs Floorboards
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
The Client
from United Kingdom
Thanked: 0 times
PostPosted: Thu Feb 22, 2007 5:49 pm    Post Subject:
Reply with quote Thanks
There are a number of threads that provide guidance on how to tile on to wooden flooring but I would like to ask for specific advise. This being. I want to lay ceramic tiles in my upstairs bathroom
, which is boarded out with 18mm chipboard, whilst minimising the height difference between old and new floor. Whilst cost is important it is of secondary importance to height difference and quality.
Is there a better product to replace the chipboard with than ply? What thickness of ply? One thread suggests 25mm yet I have other advise that suggests 18mm?
Ta
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Thu Feb 22, 2007 7:15 pm    Post Subject:
Re: Ceramic Tiles on Upstairs Floorboards
Nope - it provides good support, is stable and it's relatively cheap.
You can generally get away with 18mm but it's still a bit too flexy for my liking so I recommend using 25mm.
By the way, well done for having a look before posting - most people are too lazy.
Back to top
 Alert Moderators
The Client
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 24, 2007 11:13 am    Post Subject:
Ta
Does 18mm ply give any benefit over 18mm chipboard?
Does 25mm ply give any benefit over adding 6mm ply over 18mm chipboard?
Back to top
 Alert Moderators
alogbe
from France
Thanked: 0 times
PostPosted: Sat Feb 24, 2007 4:14 pm    Post Subject:
Like The Client, I've done some searches and made some enquiries on this and I'm confused by the number of different opinions I've found, e.g. -
"a hardboard subfloor is no good, it must be ply"
"ply is no good unless it's 15mm at least"
"15mm ply is no good, it must be 18mm" (or sometimes "25mm")
"it must be marine ply"
"it must be a hydrofuge treated OSB board such as Eurostrand"
- and today, from a 'specialist' in a tile shop:
"you don't need any of those, a flexible adhesive is OK"
Any guidance will be appreciated.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sun Feb 25, 2007 11:07 am    Post Subject:
All the information you need is on this sticky. Look half way down the page at the "timber floors" bit.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sun Feb 25, 2007 11:15 am    Post Subject:
Do you mean using ply instead of chipboard or laying 18mm ply over chipboard? You don't tile onto chipboard. If over boarding with ply, use 12mm.
Do you mean 25mm ply on it's own again 6mm ply and 18mm chipboard? I'd go for the ply every time. If you want to overboard the chipboard use 12mm (6mm is way too flymsy). You might get away with 9mm if the floor is very good and solid but to be on the safe side I'd recommend using 12mm.
Back to top
 Alert Moderators
The Client
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 25, 2007 3:23 pm    Post Subject:
Thanks for all the advice. Given that no one has suggested an alternative to ply then It is clear (given that I want to reduce the height difference) that if I want a quality Job that I should use 25mm ply. Thanks again.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sun Feb 25, 2007 5:14 pm    Post Subject:
You're doing the right thing, good luck with job.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
CERAMIC FLOOR TILING IN BATHROOM UPSTAIRS? 2 6520 Fri Sep 29, 2006 7:19 am
creaking upstairs floorboards 5 1200 Mon Apr 11, 2005 4:47 pm
Replacing upstairs floorboards 5 760 Mon Aug 08, 2005 2:36 pm
Uneven upstairs floorboards 4 400 Thu Sep 04, 2008 11:28 am
Downstairs ceiling lights shine through upstairs floorboards 2 140 Tue Sep 29, 2009 12:24 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
