Joined: 16 Nov 2006 Posts: 316 Location: United Kingdom Thanked: 0 times
Posted: Mon Feb 26, 2007 4:07 pm Post Subject:
Your not allowed to. Its not your property. Its the property of the Distribution network operator (the lecky board) you need to call them out to remove it (legally)
Joined: 21 Feb 2007 Posts: 135 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Mon Feb 26, 2007 4:25 pm Post Subject:
Call your electricity supplier and tell them that you want an isolator fitted between the meter and your consumer unit. Then there should be no need for you to remove the main fuse. I did that (phoned EDF energy) and they are coming to fit the isolator in 3 weeks time..at no charge ! Steve.
Posted: Mon Feb 26, 2007 4:31 pm Post Subject:
Really didnt they question why you wanted an isolator fitted.
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Mon Feb 26, 2007 7:52 pm Post Subject:
as bernad says provided its modern (plastic bodied), in good condition (no cracking or anything) has no signficant current flowing through it (e.g. consumer unit main swtich off) and you are carefull to only touch the plastic body when your pulling it then its not very dangerous (your still not supposed to do it mind).
if on the other hand its an old type or in poor condition or carrying significant current it could be very very nasty.
ultimately you aren't supposed to pull it but we can't stop you and the electricity suppliers don't generally bother too much about it but if you do decide to work on the supplies to your consumer unit(s) you must be extremely carefull and testing before poweron is stronly reccomended. RE-INSERTING A LARGE (60-100A) FUSE AGAINST A FAULT IS VERY VERY DANGEROUS!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
