DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Base For a Parquet Flooring
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
sleapy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Mar 01, 2007 11:38 pm    Post Subject:
Reply with quote Thanks
I am having a parquet floor fitted Herringbone Style. They are 15mm Blocks. I have floorboards which are quite solid. The guy who is fitting this has told me, who is quite experienced, as he has been laying these floors for 40 years, he is going staple and glue 4mm hardboard down as the base. Is this correct? He is also repairing an original floor in my hallway, which is laid directly to the floor boards, i think it is glued and nailed with six pins and filed with putty apparently that is how they used to do the parquet flooring, also to sell the houses by putting this flooring down. He is filling this with a mixture of saw dust etc. Is this guy right about the base and the filling in the hallway.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Fri Mar 02, 2007 12:02 am    Post Subject:
he can repair floor and use saw dust mixed with pva to fill in gaps and then final sand floor then seal. Sounds like this what they doing. As for new floor i would like to see 6mm base, whish should be plywood not hard board and should be either stapled/nailed or glued. Not both combined.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Fri Mar 02, 2007 10:45 am    Post Subject:
Matty: nailing (face-nailing) wood blocks in combination with glueing is needed when the blocks are longer than 30 - 35 cm (to press the whole block into the glue), otherwise you're correct.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
sleapy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 03, 2007 7:47 am    Post Subject:
So if i ask the guy to staple and glue down 6mm plywood, the 15mm blocks can then be laid on top of that.? If he did use hard 4mm hardboard what couold happen? Would it be so bad if he did talk me into it, as these builders etc always think they are right.
thanks very helpful
jason
Back to top
 Alert Moderators
sleapy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 03, 2007 7:50 am    Post Subject:
Sorry. You say stapled/nailed or glued not both. Do you mean Stapled and Glued or nailed and glued is ok.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Mar 03, 2007 9:54 am    Post Subject:
Jason, 4mm boards are too thin to create a stable subfloor.
__________________
Back to top
 Alert Moderators
sleapy
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 03, 2007 1:42 pm    Post Subject:
Ok i will get him to 6mm. You say stapled/nailed or glued not both. So Stapled and glued is ok.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Mar 03, 2007 1:44 pm    Post Subject:
Depends on how long and wide your blocks are?
(p.s. we normally use at least 8mm subfloor)
__________________
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Sat Mar 03, 2007 7:10 pm    Post Subject:
6mm minimum and that if sub floor o.k to start with, thicker if worse. when i say nail i mean through tongue I dont face pin as i get my subfloor within 3mm per 3meter run out. A good fitter can get floor flat without face nailing. And as you got half wooden subfoor and half concrete you should glue hole floor. Dont use hard board. This is made for people who dont know what they doing. icon_wink.gif There nothing wrong with face nailing tho.
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sun Mar 04, 2007 11:58 am    Post Subject:
My 'Dutch' mistake (again).
Whenever we talk about parquet, wood blocks I immediately think of 10mm wood blocks without T&G, which we normally glue onto 8mm mosaic subfloor and if the wood blocks are longer than 30cm they do need to be pinned down (face nailing) also.
__________________
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Sun Mar 04, 2007 6:26 pm    Post Subject:
I wouldn't call it a mistake. Both methods are fine, just yours is a bit different to mine. Think if we teamed up for a week sharing our knowledge we could learn alot of each other. More so your 'Dutch' methods for me tho. icon_wink.gif
Back to top
 Alert Moderators
sleapy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Mar 04, 2007 7:24 pm    Post Subject:
cheers guys
you are very helpful.
jason
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Mon Mar 05, 2007 12:21 pm    Post Subject:
p.s. West-midlands? What area do you cover?
__________________
Back to top
 Alert Moderators
crazycanuck
from Canada
Thanked: 0 times
PostPosted: Mon Mar 05, 2007 12:58 pm    Post Subject:
flooring
your both right but I think someone shoud mention srcrewing subfloor to remove any potental squeeks do it now you can't later
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Mon Mar 05, 2007 6:52 pm    Post Subject:
wood you like- birmingham mainly. And crazycanuck- you lost me a bit. Do you mean screw down floorboards before the ply goes down or screw the ply down? If fixing 4mm/6mm ply you would use staple or ring shank pins not screws. If ply more on 18mm side then yes you would screw it. Is this what you mean?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Base for Parquet 2 2940 Fri Apr 06, 2007 6:46 pm
Laminate Flooring - Expansion holes for kitchen base units? 2 1180 Wed Mar 26, 2008 1:04 pm
Wooden Flooring Sub-base 6 780 Mon Jan 09, 2006 1:44 pm
installation of solid wood floor - what is correct base? 4 740 Wed Oct 24, 2007 8:11 pm
Wooden floor on concrete base ? 3 1040 Thu Oct 25, 2007 12:26 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
