Mothymaggs
Joined: 07 Mar 2007 Posts: 2 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Wed Mar 07, 2007 1:36 pm Post Subject: Galaxy Aqua 3000 shower |
I have just had installed a new galaxy aqua 3000 9.5kw electric shower. Only problem is that when i switch on at the shower it just buzzes???? Any ideas? Is this a shower problem or an electrical supply problem?
Plumber can't come back until end of march due to holiday and the electrician is busy. |
securespark
Joined: 11 Jan 2004 Posts: 16485 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Wed Mar 07, 2007 5:32 pm Post Subject: |
Is the water valve open? __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
Mothymaggs
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Wed Mar 07, 2007 7:59 pm Post Subject: |
i've just checked the installation manual (http://www.galaxy-showers.com/pdfs/Fitting%20Instruction%20Aqua%203000%20'06.pdf) and it says that for first turn-on the power selector should be on cold and the flow selector fully open. |
Steve
Joined: 15 Apr 2005 Posts: 12850 Location: Yorkshire, United Kingdom Thanked: 21 times
ricicle
Joined: 14 Sep 2006 Posts: 3488 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Wed Mar 07, 2007 8:24 pm Post Subject: |
Is the shower delivering any water? If not it sounds like the inlet solenoid is suspect. __________________ Empty barrels make the most noise. |
DESL
Joined: 09 Oct 2006 Posts: 936 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Mar 07, 2007 10:07 pm Post Subject: |
I reckon shower will be kapputt.
I fitted one electrics only and plumber didn't flush pipe or carry out proper commissioning.
Normal pracise is to open water isolating valve before connecting to get rid of any debris, the run shower on cold setting without head attached until smooth flow of water. Then fit head and power up. |
