MIRA Sport Max problem
11 Mar 2007
Durham
Just installed a Mira Sport Max 10.8 Kw shower - When switched on, 'High' and 'Medium' settings result in 'Low Flow' light coming on (and staying on) after about 5 secs and water does not heat up. On 'Low' setting, 'Low Flow' light does not come on, but water still does not heat. On all settings, turning heat dial makes no difference, water is still stone cold.
Any ideas on how to solve the problem ?
Thanks - I will do. I have just discovered that I can get the shower to work when the head is low down but when shower head is at certain height the 'Low Flow' comes on again and shower goes cold. Not sure if this indicates any other problem.
johnham said:
Any ideas on how to solve the problem?
1. Isolate shower from power and water.
2. Remove water supply pipe from inlet.
3. Turn on water and measure flow rate.
4. If not within the MIs for the product, then find cause and rectify.
5. Else, return the faulty unit to the supplier and get a replacement.
For a shower as powerful as this you will need around 1.5Bar 'working' cold inlet pressure to stop the low pressure safety from cutting in ;)
OK....cleaned and replaced inlet filter and problem still there....(I am in a detached 4 year old house) and the manual states minimum maintained inlet pressure of 1bar and minimum static pressure of 0.2 bar to keep flow valve closed. Sorry for being thick but am I likely to be outside these values in a newish house or is that irrelevant here? If it is irrelevant, what is the next thing to check and can I do it myself otherwise I fear the flap of yellow pages winging its way towards me.
I'm not too surprised.
It's not likely, but it is possible.
...or is that irrelevant here?
The likelihood is irrelevant - only certainly is relevant.
...and can I do it myself
I don't see why not.
