DIYnot
Local | Network
   DIYnot > Forums
Local | Network
To hide copper pipes
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Alexx
from United Kingdom
PostPosted: Mon Mar 12, 2007 1:34 am Reply with quote
In my bedroom there are 4 central heating 8mm copper pipes that are currently nailed on top of the skirting board. I'm changing the skirting and trying to think of a better idea to lay them.
Basically, I can think of 2 ways to do this (see images).
Option 1. Is it safe to go like that? Also what cover should I use?
Option 2. Safer, to my opinion, however the skirting will be considerably thicker.
Any other ideas? Also do I need some kind of insulation between the carpet and the pipes in the second option?
Thanks in advance
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 83 times
PostPosted: Mon Mar 12, 2007 2:55 am Reply with quote
Option 2 but the skirting should go down to the floor
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1101 times
PostPosted: Mon Mar 12, 2007 8:15 am Reply with quote
What's the wall made of? You can often remove a strip of board or plaster:
Back to top
 Alert Moderators
Alexx
from United Kingdom
PostPosted: Mon Mar 12, 2007 12:40 pm Reply with quote
Thanks, it'll be too much hassle removing the plaster, plus the pipes go along 2 walls so I dont think there will be enough pipe length to do that (around the corner, if you know what I mean). I'll just go for the second option.
Thanks again to both of you
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Can I hide pipes in brick ? 6 1160 Sun Feb 06, 2005 7:37 am
Hide the pipes 10 1120 Sat May 15, 2010 1:41 am
Best way to hide pipes to towel rail radiator.. 17 480 Thu Feb 12, 2015 3:13 pm
whats the best way to hide pipes 4 860 Fri Jan 19, 2007 11:59 am
Glow Worm Hide Away 50 Issue 6 60 Tue Mar 19, 2013 10:16 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
