JoshRogan
Joined: 21 Feb 2006 Posts: 60 Location: United Kingdom
Posted: Thu Mar 15, 2007 12:08 am |
Out of curiosity - what happens when a bag of cement goes beyond the shelf life stamped on the side of the bag? (to be honest, I cant actually read the 'dots' that should make up the date!).
I've done a little searching and it seems to be related to the additives they put into the cement to reduce chances of some skin disorder because of the chromium thats in cement (is that right?!).
So, the strength of the cement is not really effected by this sell by date, but its more of a safety/handling issue?
Cheers in advance.
C. |
JohnD
Joined: 15 Nov 2005 Posts: 34355 Location: Hampshire, United Kingdom Thanked: 1087 times
Posted: Thu Mar 15, 2007 12:13 am |
It will get lumpy, by absorbing moisture from the air. and may set into a bag-shaped block.
For age, the advice is usually not to use any cement that has lumps in it that cannot easily be broken up in the fingers.
It used to be possible to buy a long-life cement, that was granulated, with a moisture-resistant coating on the granules. The coating got broken and eroded once you vigorously mixed it with aggregate. |
noseall
Joined: 02 Feb 2006 Posts: 17172 Location: Staffordshire, United Kingdom Thanked: 852 times
Posted: Thu Mar 15, 2007 3:26 pm |
agree with JohnD, though you can use crumbly but still soluble cement in concrete. |
