DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
shower tray not level
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
djshutt
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 12:31 pm    Post Subject:
Reply with quote Thanks
Hi
I have just purchased a right hand 1000 by 800 quad shower tray which Im installing myself. I have been unable to get it completely level on all sides. I can get both straight sides level but there is a fall into the middle of the curved side. If I stretch a string from corner to corner then another from the other corner to the centre of the curved side the strings do not touch where they cross, there is a 3mm gap between them. Extending this to the curved side there would be approx 5mm fall from each corner to the middle of the curved side. Apparently the retailer told me that the manufacturer says that this is within acceptable tolerances. The question I have is how am I going to fit the sliding door enclosure on top of this non-level surface. Packing it with 5mm of silicone does not sound right to me. Should the curved side be level to within tolerances which are a lot smaller than 5mm.
Cheers David
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Timmyturtle
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 4:48 pm    Post Subject:
Try a different (decent) spirit level,just in case yours is slightly out.
If you really have to fit it i would probably do the other sides 1 mm out of level.
This will not show on the tiling over that span.
Just make sure the actual part you stand in is still falling towards the waste outlet.
The most important bit to be level is where the door sits.
Back to top
 Alert Moderators
djshutt
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 6:02 pm    Post Subject:
I take your point about a better spirit level, I could do with a longer one but my existing spirit level indicates a fall from both corners into the middle of the curved side, the lowest part being about where the waste outlet is. So no matter how much I compensate by laying the other sides slightly out I will never be able to get the curved side level over its entire length. [/img]
Back to top
 Alert Moderators
Timmyturtle
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 23, 2007 6:11 pm    Post Subject:
I see....the tray at the curved part is level where the curve starts ie corner to corner but drops towards the centre of the curve from both ends
Other than a new tray.its silicone and possibly a small spacer or two hidden under the lower rail
cant see any way round it otherwise
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
installing a shower at the same level as the header tank 2 440 Thu Mar 25, 2004 10:57 am
Replacing a level access shower with a new bath (with pics) 2 280 Sun Jun 29, 2008 5:19 pm
Water tank at ground level - how can i power a shower? 6 120 Tue Aug 18, 2009 3:32 pm
Fitted new bath/shower taps, now bath not level 4 720 Tue Nov 23, 2004 8:30 pm
low level of water in wc bowl... 2 320 Fri Mar 02, 2007 3:41 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
