DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
CABLE RATINGS
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
  View previous topic :: View next topic
Author Message
LEGS
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 27, 2007 6:45 pm    Post Subject:
CABLE RATINGS
Reply with quote Thanks
A COOKER IS RATED 2950W IT SAYS IN THE MANUAL TO USE 2.5mm. CAN I USE 1.5mm HEAT RESISTANT CABLE FROM THE COOKER OUTLET TO THE COOKER? AND WHAT SIZE MCB WOULD BE SUITABLE?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mst
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 27, 2007 6:50 pm    Post Subject:
Turn your caps lock off mate ,its considered shouting in cyberspace. Then you get told off icon_wink.gif
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Mar 27, 2007 6:59 pm    Post Subject:
If the circuit is supplying ONLY this oven, do as the manual says and use 2.5mm˛, and fit a 16 amp MCB at the CU.
If there are other appliances on the same circuit or a socket on the cooker switch, which cause a higher rated MCB to be needed, you must fuse down the supply to 13 amps using a 3 pin plug or an FCU, both of which need to be accessible.
Back to top
 Alert Moderators
LEGS
from United Kingdom
Thanked: 0 times
PostPosted: Sat Mar 31, 2007 3:49 pm    Post Subject:
Sorry didnt mean to affend anyone. Jus after a bit of help. on the circuit there is a socket and rocker switch together, then it feeds the outlet plate. i thought the socket would be protected by the appliance fuse and the 1.5mm cooker cable by a 16A mcb. am i right to say a 1.5mm cable can carry around 17A?
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Sat Mar 31, 2007 10:45 pm    Post Subject:
you could put a 16A mcb on the circuit to protect the oven but that will make trips very likely if you plug anything large (say a fast boil kettle) into the socket while using the oven.
assuming the circuit is wired with 6mm or 10mm cable like a normal cooker circuit a much better bet is to replace the outlet plate with an unswitched FCU (use a good brand like MK and fit the flex first before fitting the thick hard to handle cooker circuit cable then you will be able to protect the circuit with a 32A breaker and therefore use both cooker and socket at full power at once.
as for the flex to the cooker i'd go with the size the manual asks for if only for warranty reasons. (remember if they are specifying heat resistant flex they are probablly doing so for a reason and they may not want too much electrically caused temperature rise added to that)
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Can anyone direct me to a table of current ratings for cable 10 1380 Tue Feb 05, 2008 5:54 pm
Garage MCB ratings on 6mm cable 8 2440 Fri Sep 28, 2007 8:20 pm
cable ratings 7 840 Tue Mar 16, 2004 5:17 pm
Current ratings for cable sizes 5 1700 Wed Dec 01, 2004 8:32 pm
Garden Lighting - fuse/cable ratings etc 6 820 Wed Jul 14, 2004 8:21 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
