Am replacing an old gas hob with the above to complement our existing Bosch single electric oven. Hob is rated at 6.6kw and oven 2.9kw.
Can I use the existing \\\"cooker\\\" supply (fed from 30A circuit breaker on dist board) for the new hob and switch the oven to a 13A fused plug connection via a nearby socket or will I have to run a separate cable from a new breaker on the board?
Thanks in advance for input guys.
