DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extend supply cable very short amount
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
htchmn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 9:49 am    Post Subject:
Reply with quote Thanks
I am moving skirting boards upwards by 1 inch. Sockets are set in the wall just above the skirting, so they must be moved up by 1 inch too. I am hoping there will be enough slack in the existing cables (which are buried in the concrete floor) to allow for this. If not, what do I do? Can I make a short extension to the cable tails within the mounting box? If so, what is the recommended method? Thanks for your help!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 11:34 am    Post Subject:
The best method for making connections in a confined space where the joint will not be easily accessible would be crimping or soldering. A good quality ratchet crimper is a must if you intend of making sound connections.
Use one of these with some of these for the bare earth conductor and some of these for the live conductors. Then cover the joint with this.
Back to top
 Alert Moderators
htchmn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 1:52 pm    Post Subject:
That looks the business! Thanks a lot for giving such great help.
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Fri Mar 30, 2007 2:11 pm    Post Subject:
please do not use terms such as "bare earth conductor" when talking to DIY'ers..
we know you mean "the green and yellow sleeved earth wire", but they will probably just crimp the bare conductors and forget the sleeving...
I don't mean to imply that all DIY'ers are idiots, but lets be honest, if it isn't written in black and white then some of them couldn't open a tin of paint...
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Fri Mar 30, 2007 2:31 pm    Post Subject:
But BEFORE you start crimping you need to slide the heat shrink sleeve over the cable one side of the joint area. Essential if the other ends of the cable are in-accessible or are connected to something too big for the sleeving to slide over.
Seems obvious but it still happens that the crimps are crimped and then it is found impossible to sleeve the joint.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 3:19 pm    Post Subject:
Good point, I forgot to put the link to the sleeving.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Fri Mar 30, 2007 3:24 pm    Post Subject:
I would also consider 3 individual heat shrinks over the crimps to guard against a short due to damaged insulation on a crimp when they are pressed against each other under pressure of the shrunken overall sleeve.
Back to top
 Alert Moderators
htchmn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 3:27 pm    Post Subject:
Thanks ColJack, I'll try not to take that personally!!
Just to clarify for the rest of us DIY idiots: the earth conductor on a supply cable is a bare conductor, but a green/yellow striped sleeving should be slipped over the whole of its exposed length (including both sides of any crimp) before connecting it to the earth terminals of the socket.
Back to top
 Alert Moderators
htchmn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Mar 30, 2007 3:28 pm    Post Subject:
ok, the sleeving goes over the crimp too!!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replacing endless amount of light bulbs 5 780 Tue Dec 06, 2005 7:02 pm
is there an guideline amount of lighting based on room size? 10 240 Tue Oct 20, 2009 2:46 pm
Correct way to extend 6 or 10mm cable? 14 1060 Thu Mar 15, 2007 11:11 am
Crimping to join cable to extend ring 5 380 Fri Aug 14, 2009 8:47 am
Replace socket with fused spur to extend cable ? 3 380 Fri Feb 01, 2008 8:42 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
