i have a new electric cooker and hob unit,how do i wire it? the house is re wired with a new cooker circuit,do i wire from cooker switch to oven,then take the wire from the hob unit and again put it to the oven
There is a reasonable chance the Oven has a standard 13A plug on it, so connecting to the cooker supply would not be a good idea, unless you put a Swirched fused spur in the circuit for the oven.
