DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
seal a tap to ceramic sink
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
nick wall
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 02, 2007 2:49 pm    Post Subject:
Reply with quote Thanks
I am trying to stop a leak from the joint of a monoblock tap against the sink. I do not have a large threaded nut to do up, just a single brass threaded bolt that has a horseshoe shaped plastic washer and clamp. Can anyone advise how to stop this leaking down under the sink?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
wonderb0y
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 02, 2007 2:55 pm    Post Subject:
you will have to take the tap out and tighten up the 2 flexi hoses, or the one which is leaking. it may even need the o-ring replacing
Back to top
 Alert Moderators
nick wall
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 02, 2007 2:57 pm    Post Subject:
Thanks, but it doesn't leak until you splash the water at the bottom of the tap. Just running the water doesn't make it leak.
Any ideas?
Back to top
 Alert Moderators
wonderb0y
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 02, 2007 3:17 pm    Post Subject:
thought you was on about one of the hoses, has it got a rubber o-ring or washer on the bottom of the tap that you can see? if it has it might be a case that its not seated correctly or if it has then it will need one.
Back to top
 Alert Moderators
clf-gas
from United Kingdom
Thanked: 25 times
PostPosted: Mon Apr 02, 2007 3:36 pm    Post Subject:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ceramic sink 4 540 Sat Jun 16, 2007 4:40 pm
marks on ceramic sink 2 360 Fri Feb 22, 2008 5:51 pm
Fit new mixer tap to a ceramic sink 7 220 Sat Aug 08, 2009 8:05 am
How to drill a tap hole in a ceramic sink? 13 560 Thu Sep 10, 2009 7:51 pm
tap hole for ceramic sink? 3 2020 Wed Apr 06, 2005 1:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
