DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
faulty ring circuit
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
tootie1975
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 7:24 pm    Post Subject:
faulty ring circuit
Reply with quote Thanks
On testing the continuity of the downstairs ring circuit at the distribution board,I get a complete circuit. However if I test the continuity at any of the sockets I get an open circuit. All the downstairs sockets look OK. Any comments?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Fri Apr 06, 2007 7:28 pm    Post Subject:
Silly question, but when you are checking at the sockets, have you reconnected in the consumer unit? (with power off!)
Is this typical of all the sockets you are testing?
Are you doing a proper ring final test or just 'end to end'?
__________________
Empty barrels make the most noise.
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Fri Apr 06, 2007 7:29 pm    Post Subject:
Just how are you measuring continuity at the sockets?
Have you cross linked L & N at CU?
Back to top
 Alert Moderators
tootie1975
from United Kingdom
Thanked: 0 times
PostPosted: Sat Apr 07, 2007 9:18 am    Post Subject:
faulty ring circuit
Yes I had re-connected the circuit at the CU. To test the ring circuit, I was testing across the two live and two neutral cables. I got the same readings at all the sockets and I am not sure what is meant by proper continuity test. I was testing end to end i.e. I separated the two cable ends at the sockets and put my meter on either end.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Apr 07, 2007 9:43 am    Post Subject:
you probably have a broken ring. The test you are doing is not wrong, at any socket on a ring, there should be continuity between the two reds; and between the two blacks, and between the G&Ys (however continuity on earths is not such a good indictor of an unbroken ring, as it might be finding a path through supplementary bonding and water pipes).
If you do not find continuity, get a longish piece of wire and (with all power turned off!!) look for continuity from the terminals at the consumer unit, to each of the wires in each socket. You may find it easier to start at about the middle. Of course, you must reconnect each socket after you have tested it. Make a diagram of the house and sockets and mark what you find on each.
If you have a multimeter, measure and note the resistance you find, on each wire at each socket. You can expect the resistance to increase as you get further from the CU and nearer to the break in the ring.
p.s. It is possible that you do not have a proper ring; some of the sockets may have been wired on a radial running off the ring as a spur (this is wrong if there is more than one socket on the spur)
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Has Faulty Kettle Damaged Electrical Circuit? 3 480 Mon Jun 05, 2006 2:50 pm
Faulty circuit? 24 1060 Sat Aug 05, 2006 9:06 pm
Faulty Earth on lighting circuit 4 400 Thu Sep 07, 2006 8:50 am
Faulty Circuit While Replacing Light Bulb 21 620 Sat Dec 30, 2006 4:08 pm
Faulty circuit or MCB 5 260 Wed Aug 06, 2008 11:10 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
