maxmanners
Joined: 18 Jun 2006 Posts: 7 Location: Sussex, United Kingdom Thanked: 0 times
Posted: Sat Apr 14, 2007 7:02 am Post Subject: W/mac waste pipe |
Hi
I am moving into a block of purpose built flats. Can I T into a hand sink 32 mm pipe that joins a 150mm vertical waste pipe 450 mm away? Or does it have to be a 40 mm pipe?
Regards
Max |
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Sat Apr 14, 2007 7:10 am Post Subject: |
If you Tee into your soil stack(150 mm pipe) then you will get all the nasty smells backing up from the sewers, I am not sure if it is allowed under building regs. anyway, but if it is you will need some form of trap. |
maxmanners
Posted: Sat Apr 14, 2007 7:25 am Post Subject: W/mac waste pipe |
Hi
Thank you for the rapid response.
Yes I am going to install a U bend but am just concerned is a short stretch of 32 mm pipe can handle a w/mac flow?
Max |
jj4091
Posted: Sat Apr 14, 2007 2:23 pm Post Subject: |
yes it should be ok,but make sure the end of the pipe is higher than the washbasin waste |
