DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
broken Triton hose - help !
This topic originated from the How to page called Fitting an electric shower
Click here to return to the page called Fitting an electric shower.
  View previous topic :: View next topic
Author Message
philmch
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 8:18 pm    Post Subject:
Reply with quote Thanks
Can anyone help with a broken hose on a Triton T80 ?
The basic problem is that the threaded plastic end of the hose which holds on the head has broken. I've made a temporary repair with gaffer tape.
Ideally, I'd like to replace the hose. The problem is that I can't shift it at the other end. It's jammed fast. I've sprayed WD40 into it and used grippers but no joy. It just twists the plastic bit to which it's attached and I'm scared of snapping it off.
Does anyone have any suggestions short of replacing the whole shebang ? It's at least 10 years old and working ok.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Apr 16, 2007 8:25 pm    Post Subject:
try a descaler at the other end, not wd 40
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Mon Apr 16, 2007 8:38 pm    Post Subject:
yeah try that cilit bang stuff of any limescale removal products..
and shouldn't this be in plumbing?
Back to top
 Alert Moderators
stevesey
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 8:42 pm    Post Subject:
Any chance of carefully cutting a diagonal slot in it (with a hacksaw blade), putting a screwdriver in the slot and twisting to expand/break it (if you see what I mean). Better to deliberately butcher the part you are going to replace than break the connector on the shower unit.
Back to top
 Alert Moderators
philmch
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 16, 2007 8:58 pm    Post Subject:
Thanks for your help. Sorry for posting this in the wrong place.
I've just squirted in some descaler using the syringe from an inkjet refill kit. I'll leave it overnight and see what happens.
If all else fails, I'll try the hacksaw trick. Shouldn't be too difficult. The outer section looks like aluminium.
Might try pouring hot water over it too. In theory, the metal outer will expand before the plastic inner.
Ta. Phil.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Apr 16, 2007 9:12 pm    Post Subject:
cillit bang, i was thinking more along the lines of a well known kettle descaler that i can't for the life of me remember
__________________
Forum = Opinions
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Apr 17, 2007 8:44 am    Post Subject:
You could take the unit apart so that you can remove the flow control valve to get a better grip on it.
To remove it, isolate the unit electrically, put a sheet over the shower waste, remove the cover, remove the two screws holding the flow control valve in place, pick them up off the sheet, loosen the screw at the side of the can, and ease the can forward so that you can remove the valve. Locate the rubber O ring and make sure you don't lose it or damage it.
If you do break the valve then they're available as spares from Triton.
Back to top
 Alert Moderators
philmch
from United Kingdom
Thanked: 0 times
PostPosted: Tue Apr 17, 2007 3:00 pm    Post Subject:
I got it fixed today. Thanks for all your help.
In the end, the chemical treatments didn't work at all so I did the hacksaw trick. Bought a new hose from B&Q for about £5 and it works fine although it's a bit stiffer than the old one.
Whilst I was on the job I removed all of the fittings and gave everything a damn good clean. The pole was going rusty and I've got it shining like new.
Ta. Phil.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Apr 17, 2007 3:30 pm    Post Subject:
There's nothing more pleasing than a shining pole.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Tue Apr 17, 2007 11:07 pm    Post Subject:
I wonder why a moderator moved this into the Electrics when its a pure plumbing problem of water pipes!
As the units 10 years old and they are pretty cheap I would recommend that the supply cable capacity is checked and a new shower bought with ratings within the allowable power rating of the supply/cable.
Tony
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Tue Apr 17, 2007 11:37 pm    Post Subject:
Would you recommend checking the circuit protection, and the bonding, and the cable length, and the total load at the CU, Agile?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Electric shock between electric shower hose and bath taps 8 2380 Sun Aug 26, 2007 7:21 pm
rewired hose 2004, now for the kitchen? 8 540 Sun May 15, 2005 2:32 pm
Gas cooker hose connections??!! 3 2800 Sun May 06, 2007 10:20 pm
Lofra MXD96AMFE/C broken timer 3 600 Fri Oct 19, 2007 9:32 am
Oven broken - cold dinner? 11 600 Fri Nov 02, 2007 9:47 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
