JC951
Joined: 21 Apr 2007 Posts: 1 Location: Warwickshire, United Kingdom Thanked: 0 times
Posted: Sat Apr 21, 2007 11:03 am Post Subject: RCCB not resetting |
My consumer unit has an RCCB which I think protects half of the unit. The RCCB wont reset it clicks straight off even when all the MCBs are switched to off so I only have power to half of my house. Can RCCB's be faulty or is it likely to be a fault in my wiring somewhere?
Many thanks
Jane |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Sat Apr 21, 2007 11:23 am Post Subject: |
Have you changed something recently? |
ricicle
Joined: 14 Sep 2006 Posts: 3485 Location: Gloucestershire, United Kingdom Thanked: 19 times
Posted: Sat Apr 21, 2007 11:56 am Post Subject: |
Unplug all of your appliances.Switch off any others that can't be unplugged (cooker, shower etc)
It sounds like you have a neutral to earth fault, which can still cause the RCD to trip even with the MCBs off.Try reseting the RCD with all unplugged and if it resets then plug them in one by one until you find one that sends the RCD out again.
And as Crafty said have you done any alterations/DIY lately?
If you can't find an obvious cause then I suggest you employ the services of a competant electrician, recommended to you by family/friends etc  __________________ Empty barrels make the most noise. |
