bensin
Joined: 24 Apr 2007 Posts: 1 Location: Cornwall, United Kingdom Thanked: 0 times
Posted: Tue Apr 24, 2007 10:09 am Post Subject: Single Electric Cooker to Hob and Double Oven |
I am wanting to install a separate electric hob and (possible double) oven. There is already a fitting (cable) for a single stand alone oven. What do I need to do /or check to make this possible? Thanks in advance. |
RobFurn
Joined: 16 Nov 2006 Posts: 316 Location: United Kingdom Thanked: 0 times
Posted: Tue Apr 24, 2007 11:54 am Post Subject: |
You say there is already a "fitting" for a single stand alone oven. What do you mean by fitting? is this a socket or a cooker outlet plate switched via a cooker control Unit?
The next thing to check is size of cable used in mmsq i.e. the cable has to be LARGE enough to take the load of your hob (and potential oven). Which you also need to check it will be quoted in Kw
Next is the length of cable run from your cousumer unit to the cooker as voltage drop needs to be taken into account
Also is the cable in conduit as this derates the cables current carrying capacity
There are quite a few factors as you can see
Finally its notifiable work to the LABC local authority building control office so you have to inform them if you do the work yourself and pay the fee and pay for someone to inspect
If your confident then go for it so long as you inform the LABC. If not get a spark in. |
