DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Change Wall Switch - Plastic to Chrome - Earthing?
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
benny80
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 29, 2007 12:24 pm    Post Subject:
Reply with quote Thanks
Hi
Am looking to change the wall switches from plastic to metal/chrome ones. I have a question about the earthing - Basically the metal back boxes are already earthed in that the earth cable is wired into them. The red and black cables are self explanatory, but i also have an earth connection on the back of the switch plate. This isn't mounted on the actual metal of the switch plate but white plastic. Do i also need to connect this with an earth cable and run it to the same place as where the earth cable is connected on the back box? if that makes any sense?
Any help/guidance would be appreciated
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sun Apr 29, 2007 12:43 pm    Post Subject:
Yes, get some yellow/green wire or copper & sleeving & connect the back box to the earth terminal of the switch.
Back to top
 Alert Moderators
benny80
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 29, 2007 4:43 pm    Post Subject:
Thanks. Main reason for asking is that two switches had already been done in the house (plastic to chrome) but do not have this second earch cable between the switch plate and the back box and the house was originally owned by an electrician who made these changes. Also, these lights work fine - does that mean these also have to be changed?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Apr 29, 2007 4:46 pm    Post Subject:
Yes, the switches should all have a proper earth connection to them.
Something working and something being safe are 2 different things.
Back to top
 Alert Moderators
benny80
from United Kingdom
Thanked: 0 times
PostPosted: Sun Apr 29, 2007 5:08 pm    Post Subject:
Ok Thanks. quite strange though that an electrician would not have done it correctly or 'safely'?!?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Apr 29, 2007 5:19 pm    Post Subject:
__________________
I downlights
Back to top
 Alert Moderators
benny80
from United Kingdom
Thanked: 0 times
PostPosted: Mon Apr 30, 2007 1:17 pm    Post Subject:
Ok, so i have just bought some earth cable as advised, but then realised that i have not checkd the size of the earth cable currently being used (as connected to the back box). Do you think that 1.5mm2 will be ok for what i need to do here (back box to switch plate)?
Thanks (again)
Back to top
 Alert Moderators
johnnyjb
from Ireland
Thanked: 0 times
PostPosted: Mon Apr 30, 2007 7:25 pm    Post Subject:
1.5 mm ok
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Earthing on a plastic back box with chrome face plate? 11 1940 Wed Jul 25, 2007 12:50 pm
Replacing plastic switch with Chrome 5 500 Wed Nov 09, 2005 4:59 pm
CHANGING A PLASTIC SOCKET/LIGHT SWITCH TO CHROME 4 600 Fri Dec 08, 2006 10:25 pm
changing a two way light switch plastic to chrome 6 580 Mon May 21, 2007 4:10 pm
replacing old plastic faceplate with new chrome faceplate 6 320 Sun Apr 12, 2009 3:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
