DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No hot water in Kitchen Tap
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Novice3
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 10, 2007 5:38 pm    Post Subject:
Reply with quote Thanks
We have a mixer tap in the kitchen and the hot water has just stopped coming through. It was working and then it wasn't. Not even a drip. All the other taps in the flat are fine. Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu May 10, 2007 5:40 pm    Post Subject:
Faulty tap. Try take it apart as if to rewasher and maybe you will find a bit has dropped off the assembly inside.
If you think you can put it back together successfully, fit a new washer too.
Or just buy a new tap.
Back to top
 Alert Moderators
shorky
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 10, 2007 6:43 pm    Post Subject:
is the mixer tap a 1/4 turn type, if so it will probably be of a cartridge type, they are unfortunatly all different, you will need to know make & model of tap, or if you know the make, a picture can be forwarded to the manufacture for recognition, if you are unsure you may have to change the tap completly icon_cry.gif
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
kitchen water supply 3 140 Tue Jan 23, 2007 3:31 pm
Poor water flow from kitchen tap 5 1680 Sat Nov 10, 2007 8:01 pm
Water pressure too high on kitchen tap 2 320 Tue Jul 25, 2006 12:10 pm
Overflowing cold water tank caused by kitchen tap 6 220 Tue Nov 04, 2008 1:45 pm
No hot water kitchen sink and bathroom sink 3 460 Sat Jul 22, 2006 6:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
