Gents
Missus wants lights on the patio of the type that stand upright. I am not a practising spark but many years back I did do my C & G Part1 & 2 and also the Inspection and Testing qualification. As a non practising I am a little out of date with current practises...not to mention the Part P.
I plan to run 1.5mm SWA RCD protected 6A radial circuit and connect the lights via loop in/out method. My questions are:-
1. Can I bury the SWA directly in concrete (which will then be coverd in paving slabs) or should I further protect it by feeding it in a flexible PVC conduit?
2. What depth does the cable need to be buried, hope its not 600mm like a trench feeding an outhouse.
3. How would you advise terminating the SWA at each light point. I was hoping to find a waterproof jointing box which I could use to join the cables and feed the next light as well as feeding the light at that particular point. So ideally one such as this http://www.allaboutelectrics.co.uk/index.php?doc=12&vid=1759 but with an an outlet on the lid to feed the light.
Hope someone has a solution, many thanks Julian
