Unfortunatly hotpoint do not make the filter accessible from the outside of the machine. The filter is located at the bottom of the drum in the large black sump pipe which drains the tub into the pump, it is connected onto the bottom of the tub with large black plastic bandclip or strong metal clip which has to be dismantled to give access to the plastic filter inside.
