Joined: 16 May 2007 Posts: 5 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Wed May 16, 2007 4:25 pm Post Subject:
SHOWER TRAY SLOW
My shower tray is not draining quickly, after 10 minutes the tray overflows. it also takes ages for tray to empty. Any suggestions will be helpful as the wife won't stop nagging.
Posted: Wed May 16, 2007 5:12 pm Post Subject:
Re: SHOWER TRAY SLOW
Had a friend do the work who is meant to be a plumber/builder, it now appears my ex-friend is a jack of none and a master of none and a bit of a con man, but never mind that stuff.
My waste pipe is definately 32mm, but i should be able to upgrage the trap and pipework so what size of pipework would be best????
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Wed May 16, 2007 5:15 pm Post Subject:
40mm is the minimum for a shower tray or bath. 32mm should only be used on a hand wash basin.
As Corgi says we do not know what fall etc you have. I presume you have got a continuous fall and it hasn't been 'forced' up at some point to join on to existing wastes
Joined: 25 Aug 2003 Posts: 9195 Location: Surrey, United Kingdom Thanked: 2 times
Posted: Wed May 16, 2007 5:25 pm Post Subject:
u probably have the right trap in it but as Gas says it should be 1.5 inch minimum
never mind get your solvent out
__________________ If at first you don't succeed, remove all evidence you ever tried.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
