DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Faulty tap thread?
This topic originated from the How to page called Repairing a leaking tap
Click here to return to the page called Repairing a leaking tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
ParquetGirl
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 1:00 pm    Post Subject:
Faulty tap thread?
Reply with quote Thanks
I turned off the hot water tap in my bath however when giving the tap one more turn I found that there is no resistance. The tap handle is continuing to turn but clearly is not having any effect. I have not yet tried turning the water back on but I suspect nothing will happen.
Does this mean the tap thread has worn or is there another component that is affected?
The tap is a standard victorian style, with four spokes coming out of the pillar, in a cross shape.
Many thanks!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon May 21, 2007 1:27 pm    Post Subject:
Is the spindle that the is/was attached to also turning?
If something has broken then you'll need new tap, but you might get away with a new valve body.
Photo?
Back to top
 Alert Moderators
ParquetGirl
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 1:38 pm    Post Subject:
The tap handle is continuing to turn. I can't see if anything else is turning as the tap is already tight so the spindle is not exposed. I don't have a photo but it's a standard old-tyle victorian tap with a cross shaped handle.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon May 21, 2007 1:46 pm    Post Subject:
OK. If you remove the decorative cap on top, is there a screw?
If so, if you undo it and remove the tap handle, are the splines damaged/ruined?
If so, then isolate the supply to the tap, remove the old valve body, take it to your local plumbers' merchant, buy a replacement, and fit it.
Back to top
 Alert Moderators
ParquetGirl
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 1:54 pm    Post Subject:
No idea at the moment...this happened this morning and I am now about 15 miles from the tap! Is it possible that the screw retaining the washer on the spindle has lossened and that I just need a new screw and washer?
Thanks for your help, it's most appreciated!
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Mon May 21, 2007 1:58 pm    Post Subject:
I think that's wishful thinking, but you'll soon find out!
You're most welcome; it's nice to be thanked!
Back to top
 Alert Moderators
ParquetGirl
from United Kingdom
Thanked: 0 times
PostPosted: Mon May 21, 2007 2:07 pm    Post Subject:
Well, positive thinking is essential at this stage (and at 6 am when the tap is not doing a what a tap should do!)
Will investigate further...watch this space...
Thanks again.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
1" thread shower rose 9 400 Wed Jun 13, 2007 3:13 pm
Hope u dont mind me starting a new thread replace a shower 2 740 Thu Oct 05, 2006 1:47 pm
Leaking thread couplings, how tight? 10 660 Fri Jun 29, 2007 7:28 pm
Tap tails & thread sizes? 2 560 Tue Jul 03, 2007 11:18 am
REPLACING BASIN TAPS, NEW THREAD IS LONGER, PLEASE HELP! 2 320 Mon Oct 01, 2007 2:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
