DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
thermostatic shower and (supposedly modulating) combi boiler
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jbert
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 24, 2007 5:36 pm    Post Subject:
Reply with quote Thanks
Hi there.
I've just had a new shower fitted, a 'Mira Extra', which (I think) is a thermostatic one, i.e. it adjusts the hot and cold flow to get the set temperature.
I've got a combi boiler (a Halstead Finest Gold) which the brochure says is a modulating boiler (i.e. one which reduces the gas flow when the hot water flow is reduced, so you shouldn't get a spike in temp when turning down a hot tap).
As far as I understand things, this should all work. However, the problem is that the shower drops the pressure down to a trickle over a minute or two, exactly as if it was pulling less and less water from the hot.
By turning the sink taps (when the shower isn't running) I notice that the hot water temp does vary a lot - the water is very hot when it's a trickle, which would I guess explain why the thermostatic shower is having trouble keeping up. Does this mean the boiler is playing up? Do they 'stop modulating' over time?
Do you think it's worth playing around with the different settings (hot water temp from boiler, thermostatic setting on shower, anything else?) or should I try and get the shower replaced with a manual? Is there anything obvious to check on the boiler? (pressure gauge etc?)
The shower starts off great (good pressure and temp) but then the pressure dies away, presumably as the thermostatic valve fights the boiler icon_sad.gif
Lastly, should I be asking this in a different part of the forum?
Thanks in advance for any ideas or suggestions.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
al-yeti
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 24, 2007 8:00 pm    Post Subject:
i thought because the tap is on so slow the water has a very small flow rate through the boiler hence why its very hot and varying,
also thought that some thermostatic showers can not be run direct from the boiler.
thought i would post this as no one else has replied and i might be talkin nonsense
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu May 24, 2007 8:25 pm    Post Subject:
If you run the shower as normal, can you see the boiler flame modulating down? Does hw seem ok on all other hot taps?
Is your cold supply to bath mains pressure or has it been left on a tank feed for some unknown reason?
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Thu May 24, 2007 9:04 pm    Post Subject:
There are two things you can do.
If you have a proper model turn the DHW temp knob on the boiler down from maximum to about half way and see what that does.
Otherwise run a hot water tap on half at about 3.5 li/min and that should make itr work OK although its a wasteful way of doing it.
This assumes the boiler is properly set up. As you have never had it properly serviced it may just be out of adjustment. The gas valve needs to be properly set for min and max. Not many people seem to know how to do that.
Tony
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu May 24, 2007 9:55 pm    Post Subject:
Tony
I must be naive I thought minimum and maximum settings were what we set correctly in our sleep icon_rolleyes.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
jbert
from United Kingdom
Thanked: 0 times
PostPosted: Fri May 25, 2007 8:11 am    Post Subject:
Thanks very much to everyone for the ideas.
There isn't a visible gas flame on the boiler, so I can't see if it's modulating down or not.
You might be on to something with the cold supply. Cold pressure is normally very good (e.g. bathroom sink taps) but the bath cold pressure is very low (just a trickle) It looks like a pressure reducing valve was fitted at the same time as the shower. I guess that might explain it. The shower starts at a decent temp and pressure (because the hot water is still warming up?) but once the hot gets too hot, the pressure is dropped because the cold pressure is low?
I'll try some more experimentation with the boiler hot water temperature (and having a tap running). If nothing else it'll give me more info on what's going on. I'll also see if the pressure reducing valve is adjustable and see if that helps.
Lastly, am I right in thinking that modulating boilers can "stop modulating" and that is fixable (and I should get that looked at on the next service for the boiler)?
Thanks again folks.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Fri May 25, 2007 10:57 am    Post Subject:
Gas4 U and I do set up gas valves properly but few RGis know how to do it properly. Only yesterday I met a nice guy who has been in the industry for about 8 years who had messed up that adjustment.
If there is a pressure reducing valve on the cold then thats the first point of interest! It may have a filter on the inlet which is blocked !!!
It might have drifted its adjustment and could be increased a little AFTER any filter has been checked.
Tony
Back to top
 Alert Moderators
ukboilerman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jun 09, 2008 4:48 am    Post Subject:
Re: thermostatic shower and (supposedly modulating) combi bo
jbert wrote:
Hi there.
I've got a combi boiler (a Halstead Finest[/url] Gold) which the brochure says is a modulating boiler (i.e. one which reduces the gas flow when the hot water flow is reduced, so you shouldn't get a spike in temp when turning down a hot tap).
That is a big question!
Back to top
 Alert Moderators
Moderator 11
Moderator Comment
Posted: Mon Jun 09, 2008 9:16 am    Comment:
Please note rule 9 (Please do not use excessive quoting in your posts.) - See here for the forum rules.
you seem very fond of that website but it is not permited as contact details and/or free advertising. So if you keep putting it in I will keep removing it.
please review Forum Rules
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ravenheat combi not modulating properly ? 2 220 Tue Nov 13, 2007 6:29 pm
Vaillant boiler modulating down on hotwat 2 220 Sun Dec 21, 2008 7:53 am
Is this boiler any good and is it fully modulating? Biasi... 8 660 Fri Mar 28, 2008 7:00 pm
FULLY MODULATING COMBINATION BOILER ? 30 1500 Mon Jul 24, 2006 7:15 pm
modulating valve test 19 960 Mon Feb 21, 2005 10:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
