DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Multi Source Kitchen Lighting
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
Numbskull
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 30, 2007 1:12 pm    Post Subject:
Reply with quote Thanks
Hi
I'm currently looking to wire up the lighting in my kitchen to cover three areas: icon_rolleyes.gif
Ceiling downlights
Cupboard lights
Plinth lights
At present I only have normal ceiling lights.
I would like each (having multiple lights) to be on its own switch (2 way).
Do these all need to be on their own junction boxes?
Can I use 1.5mm 2 core plus earth cable for all elements of the wiring?
What do I do when I get to the end of each multiple link of lights i.e. do I need to feed these back to anything like the junction box etc.
Please can someone help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
electronicsuk
from United Kingdom
Thanked: 23 times
PostPosted: Wed May 30, 2007 1:35 pm    Post Subject:
As is often the case, how long is a piece of string?
The cable you wire with is dependent on a number of factors, in your case (being a lighting circuit) 1.5mmsq T&E should do just fine even if there are factors to be applied.
Lights are generally wired in a radial circuit from the supply to one light to the next, you do not need to form a ring, hence the last light in the circuit will have only one incoming cable.
Re junction boxes, this depends on how your lights are wired at the moment. If you have a neutral in the same box as your switch(es) then it might be easiest to run another two additional outgoing cables from this location to your lights, and join the neutrals and CPCs in terminal blocks behind the switch faceplate. Otherwise, it might be easier for you to have one large junction box containing all the necessary wiring.
More info would be helpful...
__________________
Matthew
"I told you, I only wrote that poem to test my printer!"
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Wed May 30, 2007 6:12 pm    Post Subject:
you're obviously not capable of doing this and testing it as required and as it's a kitchen, then it's notifiable under Part P of the building regulations..
get a registered and qualified electrician in to do it..
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
SWA to Air Source Heat Pump 6 280 Tue Jan 06, 2009 4:04 pm
Anybody know where to source a 1.5" NPT immersion heate 4 200 Sun May 17, 2009 9:05 am
**INSTALLING AN OUTSIDE POWER SOURCE** 10 420 Sun Aug 02, 2009 10:59 am
ground source heat pump 8 320 Wed Sep 16, 2009 4:01 pm
Source of spurs 17 800 Thu Jan 25, 2007 10:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
