markpadgett0
Joined: 30 May 2007 Posts: 1 Location: Nottinghamshire, United Kingdom Thanked: 0 times
Posted: Wed May 30, 2007 7:43 pm Post Subject: new build radiator pipes what are they called |
i have a radiator upstairs that is leaking from the pipe where it joins the thermastat. i have never seen pipes as thin as these they are definately not your normal 19 copper pipe. it is a new build house so don\\\'t know if it is modern type of pipe. what are they called and are they easily replaced and are they pushfit or soldered? they look soldiered cause they are very thin even the bend to the thermastat. i have tried tightening the bolt to the pipe, it has slowed but still leaks.
please help any comments are greatly appreciated!
mark  |
nickso
Joined: 30 Oct 2006 Posts: 3813 Location: United Kingdom Thanked: 21 times
Posted: Wed May 30, 2007 7:51 pm Post Subject: |
most central heating copper to rads is in 8, 10 or 15mm
most likely the olive is gubbed.
if it wont tighten anymore then it needs to come off for a look and maybe a new olive. |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
nikon70
Joined: 05 Nov 2008 Posts: 44 Location: London, United Kingdom Thanked: 0 times
Posted: Sat Jan 10, 2009 9:32 pm Post Subject: |
they use plastic pipes in new builds usually 8 or 10mm |
