DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Length of cabling in a ring main
This topic originated from the How to page called Extending a ring circuit using junction boxes
Click here to return to the page called Extending a ring circuit using junction boxes.
  View previous topic :: View next topic
Author Message
sub06
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 30, 2007 9:49 pm    Post Subject:
Reply with quote Thanks
Hi I want to have sockets installed around my back garden as I am having it paved and a summer house built. Can I have the existing ring main extended to take in the new sockets, using suitable cable and waterproof sockets? also as the garden is quite large is there a limit to the length of cabling that can be used in a ring main. Many thanks - Sub06
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
pcboffinuk
from United Kingdom
Thanked: 0 times
PostPosted: Wed May 30, 2007 11:17 pm    Post Subject:
While you probably could extend the ring main, its not the way you want to do it, especially with a large garden.
The main things to think about in a garden are weather protection and rcd protection.
The best option is likely to be to run a new circuit from your consumer unit to cover just the garden sockets. Depending on distance, location etc steel wired armoured cable may be the best option. It may well be easier or more cost effective to run a radial circuit rather than a ring.
A lot depends on your house earthing, state of existing consumer unit etc. so more details on that would allow more detailed advice.
The limit of cabling is determined by the voltage drop and what you will have plugged into the sockets, but unless there are many high powered heaters or other high current using devices plugged in you are likely to be able to cover everything with one cable, it will be choosing the right size of cable etc that will require the expertise.
Personally I would advise getting at least one local electrician round to look at things - they should be able to tell you what can and what can't be done.
However, if you have any more questions, come back and someone will add further advice.
p.s. I like the MK masterseal sockets as the cover can shut and make them weatherproof with the plugs inserted into the sockets - many of the cheaper ones are only weatherproof with nothing plugged in and the cover firmly shut.
Wickes do a cheaper equivalent, although the sockets are not switched.
Hope that Helps
Gavin
__________________
foolproof systems underestimate the ingenuity of fools
Back to top
 Alert Moderators
sub06
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 8:08 am    Post Subject:
Cable length in a garden, etc
Thank you very much for your detailed advice, I am very grateful. regards Sub06
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Cable length for a ring main spur ? 7 960 Thu Aug 26, 2004 8:33 am
Max cable length/run of 2.5mm T&E ring main 5 580 Mon Apr 03, 2006 8:13 pm
Ring main length?Too long? 3 520 Fri Oct 20, 2006 5:39 pm
MAximum Cable Length for a Ring main? 5 1740 Tue Jan 25, 2005 4:33 pm
cable length for spur from ring 9 460 Sun Jun 22, 2008 7:29 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
