DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Installing electric hob & Gas oven
This topic originated from the How to page called Installing an electric cooker
Click here to return to the page called Installing an electric cooker.
  View previous topic :: View next topic
Author Message
mick240879
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 11:21 am    Post Subject:
Reply with quote Thanks
I have recently moved into a house that has a gas cooker & hob. I want to replace the gas hob with a ceramic hob using electricity & the gas oven with a new gas oven.... Can anyone advise me on any dangers or problems that i may encounter before i start? Is it difficult to do? Should i not mix gas hob & electric cooker and stick to one or the other? ... All advice welcome
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu May 31, 2007 11:45 am    Post Subject:
not answering the question but...
generally, a gas hob is better than an electric hob; and an electric oven is better than a gas oven.
Why do you want to do it the other way round?
Back to top
 Alert Moderators
mick240879
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 12:10 pm    Post Subject:
i want a ceramic hob for the asthetics and easy of cleaning it. i thought it would be easier to leave the gas installation & replace the oven with a gas one. because otherwise i thought you would have to call a gas engineer out to decomission it?
I am after advice really, so in your opinion would it be better to replace the gas with electric if i want a ceramic hob?????
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu May 31, 2007 12:16 pm    Post Subject:
If you are dead set on a ceramic hob, you will need an electric cooker circuit rated at 32A or above. Most houses already have one. There would be a large "cooker" switch above the worktop,and a large plastic plate with a Cooker Connector in the wall below the worktop, where the cooker was expected to be.
The circuit will be run in 6mm or 10mm cable, which is large.
If you do not already have a cooker circuit, you will have to have one professionally installed by an electrician who is a member of a self-certification scheme (there is an alternative process where you notifythe building control office and pay for inspection, test and certification).
If you already have such a circuit, installing a new electric cooker or hob is easy.
A typical single electric oven takes about 10-12 amps and can be run off the socket circuit using an FCU, so you can have either a gas or an electric oven, whichever you want. A double electric oven needs a cooker circuit.
Gas cookers usually have a rubber hose with a plug-and-twist fitting rather like putting in a light bulb, I don't thinkyou need a gas engineer to do that, but you may like to check your fitting and ask on the "Plumbing and Central Heating" forum, where the Corgi people hang out.
p.s. my gas hob is perfectly clean! and food spills/fat splashes do not burn on, like they do on a ceramic hob.
Back to top
 Alert Moderators
mick240879
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 31, 2007 12:22 pm    Post Subject:
Thanks for the info John D
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Installing an electric oven regulations... 5 4240 Sun Aug 07, 2005 8:01 am
Installing an electric oven 6 820 Sat Jan 07, 2006 1:55 am
installing electric oven 4 1080 Wed Jan 25, 2006 8:21 pm
installing a built in single electric oven 7 4800 Fri Mar 09, 2007 9:04 pm
Installing an electric oven 6 920 Mon Jun 07, 2004 8:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
