bertiebasset
Joined: 08 Jun 2007 Posts: 2 Location: Essex, United Kingdom Thanked: 0 times
Adam_151
Joined: 17 Jun 2004 Posts: 4539 Location: United Kingdom Thanked: 10 times
Posted: Fri Jun 08, 2007 2:44 pm Post Subject: |
What exactly is the device above the worktop 'consumer protection device' is not that informative.. are we right in assuming you just have a standard DP cooker switch? A picture may help, have a look in forum information for how to post one
Does the cable go directly to the device above the countertop? or does it go first to a cooker outlet plate below countertop level?
What size and type is the fuse/breaker for the cooker at the distribution board? |
bertiebasset
Posted: Sat Jun 09, 2007 11:02 am Post Subject: |
I thought I was ok with technology but am still trying to insert the photos I took. The device above the work surface is simply a standard cooker switch with an integrated socket for a 3 pin plug (which is currently unused). The mains cable seems go go directly to this switch as I could not see a below the counter cooker outlet plate. I also got the power outputs wrong. The Belling is rated 2.06 kW and the Hygena is rated 2.05 kW. The electric hob the current Hygena oven is connected to, is rated as 5.703 kW and is also made by Hygena. Reading the instructions from the manufacturer of the Hygena say it needs to be protected by a 13amp fuse but is hard wired permanently into the mains (and not connected by a standard 3 pin plug and 13 amp fuse that the belling is currently fitted with)
I do not know the size of the fuse at the distribution board. The cooker circuit is on the RCD protected circuit (total 63A) alongside others such as the house sockets etc.
I was planning to wire up the belling the same way as the hygena as their power outputs are so similar but was concerned about the original wiring.  |
