Joined: 21 Jun 2007 Posts: 5 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Thu Jun 21, 2007 12:16 pm Post Subject:
Timing set on Extractor
Hi, I have had a timer extractor fan fitted, its only markings are 'Model H113' and it looks quite cheap. It has a timer fitted but it stays on too long. Is it possible to change the setting?
Help please, its keeping me awake.
Kris
Posted: Mon Jun 25, 2007 6:52 am Post Subject:
The prayer quoted, is that for my benefit? Seeing as this is a HELP forum i dont mind opening my big mouth and asking an expert. Let me know anytime you need help with Metal forming processes or are you an expert on that also?
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Mon Jun 25, 2007 7:05 am Post Subject:
The signature is only normally used for a witty remark and will appear at the bottom of every one of his posts, I don't think he is getting at you personally
Joined: 27 Jul 2006 Posts: 4932 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Mon Jun 25, 2007 8:24 am Post Subject:
Thanks spark. Its on the bottom of all posts in an attempt to be witty and also as a reminder to me to keep my eye on the ball. I was trying to be helpful in my suggestion.
So no offence meant, whats the update on the fan problem BTW?
__________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Posted: Mon Jun 25, 2007 8:45 am Post Subject:
No offence taken then....... I thought it was slightly underhand, but i took it as directed at me. Not as a reminder for yourself. And seeing as i knew nothing about the subject.......blah blah.
Your advice was good, just as i thought. Although Im thinking about disconnecting the direct live altogether and leaving it controlled by the light switch. The room is only a wee toilet and hand basin. No shower.
Thanks for your help, may i suggest a new prayer.
When i get asked a question, keep it in my mind.
Whomever asked the question, is trying hard to find,
The answer that i hold, somewhere in my head
And if its one i cannot answer, i best go back to bed.
Posted: Mon Jun 25, 2007 9:05 am Post Subject:
Nice rhyme.
Re fan, I dont think it will work if u just remove the live - the switched live is a trigger and the logic board needs perm live or it wont work.
remove the perm live (and put a little term block on it so it is safe.)
put a small piece of wire between the live and switched live terminals then the fan will come on and off with the light.
Oh yes, turn off the power first!
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Mon Jun 25, 2007 9:14 am Post Subject:
I would recommend that you keep a timer conrolled fan if it is in a small toilet, any smells will not have time to be removed if you only have it connected to the light, I'm not sure if it is a building reg that you have to have a fan with a timer in those situations.
Posted: Mon Jun 25, 2007 9:26 am Post Subject:
Thanks JJ,
I dont ever intend on 'pitching a loaf' in this tiny wee room, even with the fan on the air can get a bit thick.
Originally it was to be a shower room so a fan is required ( as you would know) for that, a redraft seen us remove the shower and have it left as a WC.
The fan bugs my happiness, I only ever clean me molars in this room and its good enough for me if its on with the light.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
