Indesit WDG1295WG Motor??
24 Jun 2007
Kent
Hi all, i am not sure if my motor has gone or not, i have been reading through the forums this morning, symptoms are that my washing macine is filling up as normal, going through the cycles , but no drum movement, i thought it may be the belt, have checked that and ok, i removed the belt and switched on, it appears that the motor is still spinning, any ideas??
many thanks
steve
Sounds like the brushes have worn down & will not drive under load.
