I have recently acquired the above dishwasher however when i start a program it runs for about 4-5 mins and then trips the breaker switch in my home. If i turn the switch back on then the program resumes and within 30-45 seconds it trips again.
I opened up the machine and took the bottom off to check for shorted wires or loose pipes and all now appears fine (it had been leaking previously as the drip tray has rust all inside it but after tightening a few clips/pipes it no longer leaks).
Can anyone advise what may be causing the problem and how it may be fixed?
Any help would be much appreciated.
Many thanks.
Many thanks.
