Joined: 28 Mar 2004 Posts: 6931 Location: United Kingdom Thanked: 16 times
Posted: Sun May 09, 2004 7:34 pm Post Subject:
you can put a blanking plate on over 30A terminal block but i don't see what this gains you over leaving the socket there (possible replaceing it with an unswitched if furniture bight hit the switch)
Joined: 25 Jan 2004 Posts: 6315 Location: Vatican City State Thanked: 0 times
Posted: Sun May 09, 2004 8:05 pm Post Subject:
I am interpreting "seal it off" as make good the wall, so it looks like there was never a socket there.
If you want to do this, you will need to replace the two cables into this socket with a single cable. The ease of doing this could be anything from very easy (if for example there is a loft above the room and the ring is cabled through this loft) to very difficult (e.g. cables chased into a concrete floor).
Anything such as a junction box or a terminal block must be accessible. Now, the definition of accessible varies depending on who you ask but I think everyone will agee that hidden in a wall and plastered over is not accessible!
Here is an alternative that hasn't been mentioned: if the socket is on a stud partition wall, it should be pretty easy to put a drywall box on the other side of the wall and have an outlet or blanking plate on that side instead. This would allow you to seal up your wall on the side in question and make good.
Joined: 20 Feb 2004 Posts: 3434 Location: United Kingdom Thanked: 0 times
Posted: Mon May 10, 2004 10:57 am Post Subject:
Plug, this is not actually acceptable practice..Yes I know it goes on, but for a permanent joint that will be sealed off from view, the joint should also be permanent..as in through crimps.
Joined: 28 Apr 2004 Posts: 367 Location: United Kingdom Thanked: 0 times
Posted: Mon May 10, 2004 7:13 pm Post Subject:
I spent many years working for a local electricity board and it was deemed bad practice to crimp solid cores, nothing wrong with connector blocks, no different to screw terminals in a socket
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
