DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Extractor and Hidden Plugs
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
jbourne
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 03, 2007 2:06 am    Post Subject:
Reply with quote Thanks
I have a kitchen that's partly installed and realised that electrics for extractor not accounted for. I have a double socket with two flat grey wires going into them at ground level that would be behind oven if i left it like this but am wary of accesing these if anything goes wrong in the future. Am i able to wire from these sockets to feed oven, hob and extractor. I want easy access to all appliances and for oven and hob to plug into hidden sockets and extractor via an FCU (not an expert in any way shape or form) so that no cables are dangling around. Hope you can help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 03, 2007 3:43 am    Post Subject:
Assuming we are talking about electric hobs and ovens then you can NOT wire them both into a double socket. The hob will probably draw 20A+ which is far more than you can draw through a plug top so will need a dedicated circuit back to the consumer unit. If we are talking about the ignition for a gas hob, then yes, you can plug that in.
You may be able to get away with feeding the oven from the socket if it is <13A and again, if it is just for the ignition and small light then that too can be connected to the double socket. If the cooker is >13A then it will need to be hardwired back to the CU.
Come back with the power ratings for the hob and oven and we can advise you further.
Back to top
 Alert Moderators
jbourne
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 03, 2007 8:24 pm    Post Subject:
Wiring Hob and extractor
The oven can be fed of a 13amp fuse and the hob only requires power for the ignition. Will I have a problem with access from a regs point of view if both the points are behind the oven and cooker. If so what's the best solution.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Wires hidden in a wall. 10 760 Fri Jun 15, 2007 8:33 am
Hidden Junction Boxes 5 460 Mon Apr 14, 2008 9:51 pm
Hidden socket in bathroom - help! 4 600 Thu Apr 27, 2006 4:36 pm
hidden dimmer 2 260 Wed Jan 04, 2006 11:14 pm
Hidden kitchen electrics 11 900 Tue Mar 22, 2005 8:56 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
