DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Gravity shower pressure query
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
djbobbins
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 04, 2007 12:30 pm    Post Subject:
Reply with quote Thanks
Hi
Wonder if anyone can help me with a query regarding my shower.
We moved into a 1970s house a couple of months ago. There is an upstairs shower room, with a Mira shower fed from the hot water cylinder. I\\\'m led to believe the shower dates back to the late 90s. The header tank in the loft is of a decent size (3 foot across and a couple of foot deep at a guess) and has been built up on a plinth - giving about 2 metres of head between the shower head and the base of the header tank.
The hot water pressure at the upstairs taps is fine - but the shower is pathetic - so much so that if I take the nozzle out of the holder on the wall and point it upwards, the water just dribbles out of the jet holes.
I thought this might be to do with limescale on the shower head so I cleaned it but it has actually made the situation worse. The water in the area is quite hard and I wondered it the innards of the shower might be encumbered with limescale affecting the flow rate?
Any thoughts / suggestions much appreciated.
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Grimly Feendiish
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 04, 2007 1:54 pm    Post Subject:
Buy a new shower. B&Q have them on special offer at the moment. Better still, a power shower. But be sure to get a CORGI registered plumber to install it for you.
Hope this helps!
Grimly
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Jul 04, 2007 3:25 pm    Post Subject:
Could just need a service kit and cleaning of the cartidge.
NEVER buy anything from B&Q you won't get good service.Go to a local plumbes merchant.
You don't need to have a CORGI in to fit a shower icon_eek.gif not unless you are planning another holocaust icon_lol.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Jul 04, 2007 6:40 pm    Post Subject:
Hope this helps!
Grimly
How many shares do you have in Kingfisher? You're always recommending B&Q boilers and stuff.
Back to top
 Alert Moderators
djbobbins
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 06, 2007 6:23 pm    Post Subject:
so what's the craic with a service kit? I am feeling a plumber's bill coming on...
Back to top
 Alert Moderators
JPC
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 06, 2007 7:08 pm    Post Subject:
is the shower pressure crap even when you lower the head to the height of the bath taps. is the bath tap pressure ok ?
have u taken off the hose/head and seen if any blockages ?
have u checked from where the shower if fed ?
i assume the cold is also tank fed ?
r u saying there is 2m from water level to shower height ?
is it fed from the bath taps or a mixer on the wall ?
ah yes.....dont buy from b and q (although they do have there uses) and just to repeat.....corgi is only gas stuff and there safety -not an indication of quality work either !!!
__________________
Jamie
Back to top
 Alert Moderators
djbobbins
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 06, 2007 8:48 pm    Post Subject:
Many questions, answers in order:
shower pressure / flow is still dreadful when showerhead is reduced to tap height and pressure on the taps is fine
have taken off showerhead and no blockage (water flow out of hose still dreadful with head off)
not checked where shower is fed from
there is at least 2m of head to the exit point on the cold water header tank in the loft - so probably 2.5m to the surface of the water
It is a Mira Excel fed from a mixer on the wall, not from bath taps
Thanks for showing interest!
Back to top
 Alert Moderators
Onetap
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 06, 2007 9:01 pm    Post Subject:
Hope this helps!
Grimly
Why?
CORGI does gas, nothing but gas. Showers use water. Many Corgis are clueless about anything but gas and they aren't too good on the gas either.
Be sure that you get a competent non-Corgi plumber.
Back to top
 Alert Moderators
Onetap
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 06, 2007 9:07 pm    Post Subject:
Check the isolating valves from the tank to shower valve are fully open.
Get the installation and maintenance manual from the manufacturer's website. Check whether there are strainers/filters on the shower inlet and, if so, descale them.
Get a service kit, dismantle, descale and re-assemble the shower valve (or pay someone to do it for you). You probably need to do that every year or 2 anyway.
Check the shower hose isn't perished and restricted. Some cheap ones have a narrow, restrictive bore when new.
That should sort it.
Back to top
 Alert Moderators
Onetap
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 06, 2007 9:13 pm    Post Subject:
gas4you wrote:
Not a laughing matter.
Really.
I apologise for him.
In the great mosaic of victory, I lay this priceless jewel, my only son.
On a headstone in a cemetery in Holland.
Back to top
 Alert Moderators
djbobbins
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 06, 2007 9:16 pm    Post Subject:
Cheers
Have had a look around, found the manual and it's definitely got inlet filters on both hot and cold.
Will get a service kit and see how I get on.
Hose is not perished and has got a decent sized bore (well, 10mm or so, not 5-6mm like some I've seen in shops, as you say.)
(P.S. - to all above who mentioned Corgi, even I know Corgi registration isn't needed for water work; much better to go by recommendation. Unfortunately moving to a new area makes that a bit tricky...)
Back to top
 Alert Moderators
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Sat Jul 07, 2007 2:18 am    Post Subject:
deleted! **
Back to top
 Alert Moderators
djbobbins
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 30, 2007 1:07 pm    Post Subject:
Success!
Changed the inlet filters and shower is vastly (and I mean vastly) improved.
Bit concerned that the isolation valves on both the hot and cold water feeds to the shower didn't isolate properly but at least I can get clean now.
Once I'd drained the header tank down (owing to duff valves) dismantling the shower, changing filters and reassembling took under 10 minutes.
top banana...
Back to top
 Alert Moderators
Buzzark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 30, 2007 2:43 pm    Post Subject:
If you're changing the valves, fit full bore lever valves.
You won't be restricting the flow then through the valve and when we were gravity fed this did help a bit.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Gravity fed pipework query 4 200 Sun Sep 21, 2008 11:22 am
Wiring query for Gravity system 29 3860 Thu Nov 15, 2007 1:06 pm
Minimum pressure for gravity fed shower 5 160 Tue Oct 27, 2009 12:12 am
Loss of pressure from gravity tank? 9 340 Sun May 04, 2008 9:00 am
Lack of Gravity fed pressure on non pumped heating circuit 3 120 Tue Dec 02, 2008 2:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
