Range oven not sparking
26 Aug 2005
When i turn the oven on my range oven does not always spark to ignite the gas. The gas is coming through but the auto ignition spark does not always work. The gas rings are fine, they have a button to press for ignition.
Tried cleaning the electrodes but still same
thanks
Is the centre electrode shorting to earth & how big is the gap between the centre electrode & the earth electrode? Do the oven & hob use the same spark generator?
cant see any shorting and electrodes look clean. The gap is 3mm. Not sure if they are using the same spark generators havn't got that far yet. The cooker is a Leisure Rangemaster 110.
You will need a multimeter to test for a short circuit , sorry cannot suggest anything else until you eliminate those things for certain.
I have a multimeter, can i test from the electorde?
Is the 3mm gap ok?
yes, set the multimeter to resistance/ohms & check that there is no conductivity between the centre electrode & earth.3mm is fine
