orcasinger
Joined: 22 Jul 2007 Posts: 2 Location: Canada Thanked: 0 times
Posted: Sun Jul 22, 2007 3:51 pm Post Subject: kitchen taps |
I have just installed new Delta kitchen taps including a sprayer hose. The sprayer hose leaks from the nozzle for some reason as well at the tap for a couple of drips after I shut the water off. There are no leaks under the sink at all.Help frustrated |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Sun Jul 22, 2007 4:04 pm Post Subject: |
Don't know this make of taps, but it is generally quite common for drips after mixer tap has been turned off, but only for a couple of seconds or so. __________________ Dave
DRL Gas Services |
orcasinger
Posted: Sun Jul 22, 2007 11:01 pm Post Subject: |
It also drips while the water is running out of the spout and then also after the water is shut off completely. It's frustrating because I paid alot of money for these taps but installed myself so I'm not sure if there's not one little thing that I did wrong. Seems to me this always happened with the spray hose and I replaced it once before and still the same thing. The only time it didn't do it was when the nozzle was actually broken and wouldn't turn on. |
