tino
Joined: 26 Jul 2007 Posts: 1 Location: Buckinghamshire, United Kingdom Thanked: 0 times
Posted: Thu Jul 26, 2007 10:34 pm Post Subject: Wobbly toilet suggestions? |
Our toilet bowl is rather wobbly. Not being particualrly DIY-minded I wondered if anyone knew a)how the bowl should be secured when first fitted(I'm fairly sure ours is only screwed into the floorboards) and b)how to revolve this problem without having to do anything beyond my limited capabilities! |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Thu Jul 26, 2007 10:37 pm Post Subject: |
Screws are normally used - unless rust proof ones were orignally used then they'll be useless now.
Unless you can tighten them the loo will need removing and the floor inspected. If the boards are OK then you could refit the loo with larger Brass screws designed for the purpose.
If the floor is rotten as well as the screws then check for a leak. __________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man |
bathjobby
Joined: 06 Oct 2004 Posts: 1052 Location: United Kingdom Thanked: 0 times
Posted: Fri Jul 27, 2007 4:08 pm Post Subject: |
Assuming none of the above and its just and uneven floor, I would do (and have done) the following. Loosen the screws and wobble the pan to determine which part of it needs something under it to stop it wobbling. Get yourself some varied tie wraps (the sort the military now use as handcuffs), the thickness varies with the length. Offer them end on into the gap to be filled to determine which thickness you need to stop the wobble, then insert end on as many as needed. Screw the pan down tight and check wobble has gone. Cut of the external tie wrap ends as close to the pan as possible (stanley knife) and seal round the bottom of the pan to cover them and fill the gap. |
