DIYnot
Local | Network
   DIYnot > Forums
Local | Network
upvc door
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
goofy gorilla
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 27, 2007 2:54 pm Reply with quote
hi guys..i just installed a new upvc kitchen door, however the bottom of the frame resting on the floor seems to be letting water in, even though i cemented the gap at the bottom when installing...how can i prevent further water coming in when it rains ...see pic below.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Fri Jul 27, 2007 4:19 pm Reply with quote
Can you do another photo from the front or outside?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Fri Jul 27, 2007 5:55 pm Reply with quote
How much clearance do you have under the door when open? It looks almost on the concrete floor!
Back to top
 Alert Moderators
goofy gorilla
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jul 27, 2007 6:53 pm Reply with quote
it looks like its on the floor but it isnt, its 1" above the floor..ive filled the gap underneath with cement....well a mixture of screeding sand and cement, thats what the builder left behind so i mixed that up and used it..pic from the outside of the door..
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sat Jul 28, 2007 8:59 am Reply with quote
I think that's the problem, my guess is the rain is soaking through the cement under the cill, might be an idea to buy a top cill profile type and put it under the gold cill and finish off with sealant to keep the driving rain off.
Back to top
 Alert Moderators
Watchmaker
from United Kingdom
PostPosted: Sat Jul 28, 2007 9:35 am Reply with quote
As an amateur, my view is that you have done everything right except the mounting of the weatherstrip device which the door closes against. I assume, when the door closes, it meets a rubber/neoprene type of seal, set into the inside face of the weatherstrip/threshold. The door, when opening and closing, is likely to impart some slight movement to this threshold and the seal, between it and the cement filler on which it is mounted, is disturbed.
I would suggest the you take out the threshold and apply some mastic filler for it to seat on. together with a fillet of mastic at the two ends. before firmly screwing it back to the base. Also, a check on how close the threshold is to the fully closed door, would be worthwhile. Is the door compressing the rubber seal sufficiently to effect a good watertight seal ?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sat Jul 28, 2007 3:51 pm Reply with quote
I'm thinking did the gold bar come with the door? I think you may have a upvc cill missing!
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1322 times
PostPosted: Sat Jul 28, 2007 4:04 pm Reply with quote
the problem is, the concrete step is drawing the water in under that low threshold, and is relying on what ever adhesive/sealant that is present between the two, to keep the water out.
i would have cut the step back into the room by 3", and down by one course of bricks. i would have made the door with a stub sill and set the frame height so that when the door opened it cleared the floor and whatever i decided to put on the floor, i.e. carpet, tile, laminate etc.
this way, at least the stub sill offers protection against the weather, plus by setting it down slightly, the deepish threshold would not be too intrusive.
Back to top
 Alert Moderators
JFC
from United Kingdom
PostPosted: Sun Jul 29, 2007 6:11 pm Reply with quote
Did you know your weather bar is missing its D shaped rubber ?
Back to top
 Alert Moderators
goofy gorilla
from United Kingdom
Thanked: 2 times
PostPosted: Sun Jul 29, 2007 9:20 pm Reply with quote
the door shuts nice and tight against the seal, so no water comes through there..the gold strip came with the door...im thinking that it may be the cement on which the frame is sitting..it might be letting the water through...then again it may be that it needs a plastic cill on the outside...where di i get that from ?...cheers
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Leaking front uPVC door 7 1620 Thu Mar 03, 2011 8:57 pm
upvc door not closing properly 4 2200 Wed Mar 09, 2011 3:02 pm
UPVC Front door - New handle and Lock - Pls help 5 200 Tue Mar 15, 2011 8:41 pm
UPVC door operating problem 2 140 Fri Feb 11, 2011 1:08 pm
New UPVC door Adjustable hinges? 2 240 Sun Jan 30, 2011 7:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
