DIYnot
Local | Network
   DIYnot > Forums
Local | Network
which is the most reliable boiler
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
lxbn
from United Kingdom
PostPosted: Wed May 19, 2004 5:05 pm Reply with quote
As I am having my old boiler replaced (choice between the Ideal Classic SE21 and Worcester Bosch 14/19 CBi), I trawled through most of the posts here abt the unfortunate problems folks have been having with their boilers, but I haven't come across even one concerning an Ideal boiler (or the above type of Worcester Bosch). Are these boilers really that good or is no one telling! Does anyone have an unbiased opinion between these two boilers - I obviously would like one that would give me years & years of blissful & untroubled operation!
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Wed May 19, 2004 9:23 pm Reply with quote
ideal classic just about the most reliable trouble free boiler you can get. Been around for a number of years now .The optia range exclusive to plumbcentre is the exact same boiler just rebadged and a bit cheaper with a fixed price so priceyou see is the price you pay
Back to top
 Alert Moderators
lxbn
from United Kingdom
PostPosted: Fri May 21, 2004 7:52 am Reply with quote
Thanks. That was my feeling only I couldn't help being impressed with the Bosch name. Now I just need to convince my installer who is sold on the Worcester Bosch!
Back to top
 Alert Moderators
madpiano
from United Kingdom
PostPosted: Sat May 22, 2004 7:34 pm Reply with quote
If anyone asks me, I would never recommend Ideal. We live on a new built (well, 6 years ago now) housing estate. All but 3 houses had Ideal Combi Boilers installed. Within the first year, all ideal boilers developed one or several minor faults, more of them over the next 2 years and now, year 6, everyone needs new boilers, as they are beyond repair (most of them developed hidden leaks inside and blew up eventually). Now we are 21 houses here. 3 Houses (they are bigger) had Vaillants installed. They didn't have a single problem since they moved in. 18 Ideal Boilers have now gone to the scrap heap....If that tells you anything.....
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 786 times
PostPosted: Sun May 23, 2004 7:17 am Reply with quote
For reliability go for a 'copper brick' in the fireplace and a coal. Nothing to go wrong. You have coal so you have heat.
No modern boiler is made like a brick outhouse. They would appear to have finite life. If you think you are going to get 30 years from your high efficiency singing dancing aluminium heat exchanger condensing boiler with loads of fuel saving, you may well be disappointed.
Some may not agree with me, but major chunk of my work is boiler repairs and service- hardly ever fit boilers.
Some old boilers still running reliably are listed below. A lot of these will still be chugging along when proposed HF new toys are dead and gone. I label a boiler reliable that is 8 years and over (subject to regular service as per the manual) to run for twice that.
Vaillant T3
Vaillant VCW
Vokera Turbo
Vokera Flowmatic
Vokeras about 8 years old
Potterton Kingfisher
Potterton Prima
Gloworm
T3 can be 25 years old, VCW are about 15, Turbo (Flowmatic shares a lot of components with Turbo) can be around 18 years old.
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 786 times
PostPosted: Sun May 23, 2004 7:19 am Reply with quote
Vaillant T3
Vaillant VCW
Vokera Turbo
Vokera Flowmatic
Potterton Prima
Gloworm
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sun May 23, 2004 7:38 am Reply with quote
IXBN dont be put off by Madpiano`s comment about Ideal Combi`s as this is completely different boiler and can be a complete pile of s##t . It amazes me how a manufacturer can get it so right with one boiler and so so wrong with an other.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Sun May 23, 2004 4:22 pm Reply with quote
Yea - if you want a reliable boiler, avoid combis. But if you must have one, DP's list is as good as any. The Ideal Classic is as described.
There's a boiler breaker near me who buys "removed" boilers for salvage, from local heating bods. If they're good he refurbishes them, so he knows his stuff. He reckons anything currently produced won't be worth repairing after 4 or 5 years. Maybe he's a bit cynical, but not good to hear, is it?
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Sun May 23, 2004 4:37 pm Reply with quote
Ideal classic is a gem of a boiler, the fan will wear out in time but nothing else will.
Go for something simple I am running a potterton flamingo BF. It has required a new gas valve and a few thermocouples but not bad in 26 years.
Back to top
 Alert Moderators
m8tte
from United Kingdom
PostPosted: Mon May 24, 2004 11:35 am Reply with quote
I am getting my boiler replaced and have been suggested a Potterton Suprima L
one company quoted for a 60,000 btu
another go for an 80,000 btu
Q Are these any good?
(is that the ones mentioned above prima - or is that different??)
Q and is it better to go for the bigger btu one - or will that cause problems????
Back to top
 Alert Moderators
lxbn
from United Kingdom
PostPosted: Thu May 27, 2004 4:20 pm Reply with quote
Thanks for all the comments. I agree with the general opinion - from all I've seen here combis are a swine and I wouldn't consider one unless I had no choice. namsag I think is right, the Ideal Classic is a different beast from it's combis cousins, I too have heard of problems with Ideal combis.
My boiler, thanks to warmer weather will be installed in early July. My installer's first choice is the Worcester Bosch 14/19 CBI or I can opt for the Ideal Classic SE18 for 184 + VAT more. I'd rather have the Ideal but I haven't heard anything nasty about the Bosch so I have a few weeks before I toss a coin.
For m8tte, I'm no expert and I don't want to damn the Potterton Suprema, but it is one boiler I wouldn't consider from the start but I cannot remember why......
Back to top
 Alert Moderators
m8tte
from United Kingdom
PostPosted: Thu May 27, 2004 4:36 pm Reply with quote
lxbn - sorry i hijacked your thread a bit! icon_wink.gif - I have started a new one
Pot suprema seems they have probs with boards
i just dont know what to get !!!
Potterton profile l seem better better
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Fri May 28, 2004 7:29 am Reply with quote
IXBN. Dependent on where your installer has an account ask them to use the Optia boiler exclusive to plumbcentre as this is an Ideal classic with a different badge there is no difference except it about 60 cheaper.
Back to top
 Alert Moderators
seanfhear
from United Kingdom
PostPosted: Sun Jan 30, 2005 8:38 pm Reply with quote
My first attempt at entering this forum! It seems that the difference is more than just a different badge. On looking at the Optia brochure showing the view of the interior, it shows what appears to be the fan switch mounted at the top r/h side of the heat exchanger, whereas the 08/99 brochure from Carodon omits showing this position. It is possibly mounted on the fan assembly (or wherever)? Are we looking at an earlier model or a set-up purely manufactured for Plumbcentre. Eitherway, is there a Gas Council reference number for the Optima boiler and its associated components?
This number/s will be required for future spares reference. Plumbcentre operatives are at a loss as to what I am referring to. Do I buy an Optima or an Ideal Classic F.F., no matter what the model?
Back to top
 Alert Moderators
PEDANTICVINDICTIVEMAN
from Western Sahara
Thanked: 1129 times
PostPosted: Sun Jan 30, 2005 9:10 pm Reply with quote
Haaaaaaaaaaaa haaaaaaaaahaaaaaaaaaaaa haaaaaaaaa haaaaaaaaa haaaaaaaaaaaaaaaaaaaaaaa bonk, fell off me chair with that one, got anymore cough cough gasp gasp.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Looking for reliable 24kw boiler for open vent system. 15 1620 Tue Mar 30, 2010 6:30 pm
Which is the best (ie most reliable) boiler brand 10 6240 Wed Feb 28, 2007 12:09 pm
Need Reliable boiler 4 720 Wed Oct 14, 2009 4:54 pm
Most reliable condensing boiler? 45 6240 Sun Jun 29, 2008 10:04 am
the most energy efficient and reliable boiler 3 1160 Sat Sep 13, 2008 7:06 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
