donkeyyy
Joined: 09 Aug 2007 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Thu Aug 09, 2007 5:38 pm Post Subject: 28mm o.d black pipe |
i have a leaking black plastic pipe just before the stopcock it seems to be about 28mm outside diameter .
any ideas about the make of pipe and would i need any specialist fittings  |
chr15
Joined: 22 Jun 2004 Posts: 537 Location: Carmarthenshire, United Kingdom Thanked: 0 times
Posted: Thu Aug 09, 2007 5:55 pm Post Subject: |
Sounds like alcathene,you need to get the exact outside diameter and then visit your plumbing merchants and get a fitting to repair it-where is it leaking from? |
donkeyyy
Posted: Thu Aug 09, 2007 6:26 pm Post Subject: |
it has a small pin hole about 30 mm below stop cock ,making a right mess too.
managed to get a bit of rubber hose an jubilee clip on it |
chr15
BoxBasher
Joined: 01 Nov 2006 Posts: 998 Location: United Kingdom Thanked: 0 times
Posted: Thu Aug 09, 2007 7:54 pm Post Subject: |
Any coloured stripes on the pipe? This will classify the wall thickness of the pipe. |
chrishutt
Joined: 20 May 2005 Posts: 5346 Location: St. Pierre and Miquelon Thanked: 2 times
Posted: Thu Aug 09, 2007 10:20 pm Post Subject: |
The pipe will be ¾" polythene, which has an OD of 27mm. If you can turn off the water upstream of the leak you could cut out the pin-holed section and refit the stop tap and liner to the new, undamaged end. __________________ Let's face FAQs. |
donkeyyy
Posted: Sun Aug 12, 2007 6:04 pm Post Subject: |
thanks for all the tips lads, i cut out a section of pipe and took it to the local plumb centre turned out to be 27mm black alkathene.
the guy behind the counter gave me a push on fitting to take me from the 27mm alkathene to 22mm copper , got to say had my doubts but it worked a treat.
cheers all  |
