infamy9
Joined: 10 Aug 2007 Posts: 2 Location: Sussex, United Kingdom Thanked: 0 times
Bahco
Joined: 08 Feb 2004 Posts: 6462 Location: Wolverhampton, United Kingdom Thanked: 5 times
infamy9
Posted: Sat Aug 11, 2007 8:08 am Post Subject: Tivoli shower maint |
I assume direct from the hot water cylinder. |
Bahco
Posted: Sat Aug 11, 2007 9:42 am Post Subject: |
In that case, tie up the ball valve to a piece of wood resting on the cistern which will cut supply to it.
Run off an upstairs cold bath tap until it stops, and then run off your hot bath tap.
You can now work on your shower.
| Quote: | | I assume direct from the hot water cylinder. |
Not really a good idea assuming!
Make sure or you will get wet.  __________________ 85 weeks without smoking! |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sat Aug 11, 2007 10:14 am Post Subject: |
Then search the forum for how to deal with airlocks...  . __________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man |
